Active Directory
This connector exports and fulfills users and groups from/to an Active Directory instance.
This page is about Directory/Active Directory. See the Active Directory topic for additional information.
Active Directory is a directory service developed by Microsoft for Windows domain networks. The Active Directory connector exports Active Directory (AD) entries to Identity Manager's resource repository. This connector also enables automated provisioning from the resource repository to the AD.
Prerequisites
- Reading first the appsettings documentation; See the appsettings.agent topic for additional information.
- Opening the LDAP feed from Identity Manager's server to the Active Directory, with the ports 389 for LDAP and 636 for LDAPS.
- A service account with reading and writing permissions on the target Active Directory instance. It means that the Replicating Directory Changes rights are required for the service account, but also for the Active Directory root and the AD children. See the instructions below for additional information.
- An SSL connection which is mandatory for the AD connector to initialize and change a password.
- Enabling rights inheritance in the Advanced Security Settings.
Enable Active Directory Permissions
To enable permissions, the Active Directory administrator must do the following:
Step 1 – Check the View details in the Active Directory and Computers.
Step 2 – Open the Advanced Security Settings dialog box for the domain root.
Step 3 – Select the Replicating Directory Changes check box from the list.
Step 4 – To change groups' membership, in the Applies field, select Descendent Group object and select the Read Members and Write Members check boxes from the list.
Step 5 – To Reset Password capabilities, in the Applies field, select Descendent User object and select the Read lockoutTime and Write lockoutTime check boxes from the list.
Administrator rights must not be granted to the service account. Doing otherwise would create a security breach. Administrator rights must only be granted to the target perimeter.
Export
For a configured set of Active Directory entries, this connector exports all attributes from the connector's configuration to CSV files.
The export is executed by a job from the UI, or via Identity Manager-Export-ActiveDirectory.exe in the command prompt.
Configuration
This process is configured through a connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section:
script in the command line.
"Connections": {
"<ConnectionIdentifier>": {
- Be unique.
- Not begin with a digit.
- Not contain
<,>,:,",/,\,|,?,*and_.
The following example configures a connection to the Active Directory Domain Controller contoso.server.com using Basic Authentication with BaseDN, Login, Password with EnableSSL for all entries ( "Filter": "(objectclass=*)"):
<>need to be replaced with a custom value before entering the script in the command line.appsettings.agent.json{..."Connections": {"ADExport": {"Filter": "(objectclass=*)","Servers": [> {"Server": "contoso.server.com","BaseDN": "DC=contoso,DC=com"}],"AuthType": "Basic","AsAdLds": false,"EnableSSL": true,"Login": "Contoso","NoSigning": false,"Password": "ContOso$123456789","RetryDelay": 10}}}
Setting attributes
| Name | Type | Description |
| Servers required | Server List | List of pairs that define the target servers, made of: - Server: domain controller URL. - BaseDN: base Distinguished Name used to connect to the related server. |
| AsAdLds optional | Boolean | True to state the managed system as an AD LDS. It is used for extracting the schema through the connection screen. |
| EnableSSL optional | Boolean | True to enable SSL protocol for authentication requests. recommended when using AuthType set to Basic because basic authentication packets are not encrypted by default. SSL is not available on Linux. |
| NoSigning optional | Boolean | True to disable Kerberos encryption. |
| AuthType default value: Negotiate | String | Authentication method used by Identity Manager to authenticate to the server. Access is granted to the target domain controller: Anonymous - without any login/password; Basic - via the BaseDN, Login and Password attributes; Negotiate - via GSS-API negotiations with the Kerberos mechanism used for authentication. |
| Login optional | String | Login used by Identity Manager for basic authentication. It is required when AuthType is set to Basic. |
| Password optional | String | Password used by Identity Manager for basic authentication. It is required when AuthType is set to Basic. |
| Filter required | String | Value that filters out the corresponding entries from the AD instance which will not be exported. Only non-filtered entries are exported. The filter value complies with Microsoft's search filter syntax. |
| RetryDelay optional | Int32 | Time (in milliseconds) after which Identity Manager retries a timeout request. |
| RequestTimeout optional | Int32 | Time (in seconds) after which a connection faces a timeout. |
| ConnectionTimeout optional | Int32 | Time (in seconds) after which a connection faces a timeout. |
Output details
This connector is meant to generate:
A file named
<connectionIdentifier>_entries.csv, with one column for each property having a ConnectionColumn and each property without it but used in an entity association;Any property can be exported in a specific format when specified. See the References: Format for the EntityPropertyMapping topic for additional information.
An additional file for each related table other than entries;
A cookie file named
<connectionIdentifier>_cookie.bin, containing the time of the last export in order to perform incremental exports.noteMost exports can be run in complete mode, where the CSV files will contain all entries, or in incremental mode, where CSV files will contain only the entries which have been modified since the last synchronization.
A task can use the IgnoreCookieFile boolean property, and a command line (with an executable) can use the option --ignore-cookies.
The CSV files are stored in the ExportOutput folder, and the cookie file in the ExportCookies folder. See the Application Settings topic for additional information.
For example, with the following configuration example:
<EntityType Identifier="AD_Entry" DisplayName_L1="AD - Entry" > <Property Identifier="dn" DisplayName_L1="dn" IsKey="true" TargetColumnIndex="0" Type="String" /> <Property Identifier="objectCategory" DisplayName_L1="objectCategory" TargetColumnIndex="4" Type="String" /> <Property Identifier="objectGuid" DisplayName_L1="objectGuid" TargetColumnIndex="3" Type="String" IsKey="true" /> <Property Identifier="objectSid" DisplayName_L1="objectSid" TargetColumnIndex="9" Type="String" /> <Property Identifier="pwdLastSet" DisplayName_L1="pwdLastSet" TargetColumnIndex="13" Type="String" /> <Property Identifier="thumbnailPhoto" DisplayName_L1="thumbnailPhoto" Type="Binary" /> <Property Identifier="ParentDn" DisplayName_L1="ParentDN" Type="ForeignKey" TargetColumnIndex="128" /> <Property Identifier="children" DisplayName_L1="children" Type="ForeignKey" /> <Property Identifier="Member" DisplayName_L1="Member" Type="ForeignKey" /> <Property Identifier="memberOf" DisplayName_L1="memberOf" Type="ForeignKey"/></EntityType><EntityTypeMapping Identifier="AD_Entry" Connector="AD" ConnectionTable="ADExport_entries"> <Property Identifier="dn" ConnectionColumn="dn" IsUniqueKey="true" /> <Property Identifier="objectCategory" ConnectionColumn="objectCategory" Format="rdn" /> <Property Identifier="objectGuid" ConnectionColumn="objectGuid" IsPrimaryKey="true" Format="guid" /> <Property Identifier="objectSid" ConnectionColumn="objectSid" IsUniqueKey="true" Format="sid"/> <Property Identifier="pwdLastSet" ConnectionColumn="pwdLastSet" Format="1601date" /> <Property Identifier="thumbnailPhoto" ConnectionColumn="thumbnailPhoto" Format="binary" /></EntityTypeMapping><EntityAssociation Identifier="AD_Entry_parentdn" DisplayName_L1="Parent DN" IsProperty1Collection="true" Property2="AD_Entry:ParentDn" Property1="AD_Entry:children" /><EntityAssociation Identifier="AD_Entry_member" DisplayName_L1="Member" IsProperty1Collection="true" IsProperty2Collection="true" Property1="AD_Entry:Member" Property2="AD_Entry:memberOf" /><EntityAssociationMapping Identifier="AD_Entry_parentdn" Column2="dn" Column1="parentdn" ConnectionTable="ADExport_entries" EntityPropertyMapping1="AD_Entry:dn" EntityPropertyMapping2="AD_Entry:dn" Connector="AD" /><EntityAssociationMapping Identifier="AD_Entry_member" Column1="dn" Column2="member" ConnectionTable="ADExport_members" EntityPropertyMapping1="AD_Entry:dn" EntityPropertyMapping2="AD_Entry:dn" Connector="AD" />
We would have C:/identitymanagerContoso/Temp/ExportOutput/ADExport_entries.csv with a column for each
scalar property. See the Entity Model topic for additional
information.
command,dn,objectCategory,objectGuid,objectSid,pwdLastSet,thumbnailPhoto,parentdn
Also, ADExport_member as ConnectionTable in a mapping will trigger the generation of the file
C:/identitymanagerContoso/Temp/ExportOutput/ADExport_member.csv with member as link attribute:
ADExport_member.csv
command,dn,member
And C:/identitymanagerContoso/Work/ExportCookies/ADExport_cookie.bin
Synchronize multiple forests
This connector can export resources from multiple forests trusted by the same AD domain.
It requires specifying the Server and BaseDN pairs in Servers for all the forests used as source for the export.
Each BaseDN will generate a cookie file, but the entries from all BaseDN properties will be written to the same CSV file.
The following example exports data from two sources: both on the same Server (contoso.server.com), but on two different BaseDNs (DC=contoso,DC=com and DC=defense,DC=contoso,DC=com).
<>need to be replaced with a custom value before entering the script in the command line.appsettings.agent.json{..."Connections": {"ADExport": {"Servers": [> {"Server": "<contoso.server.com>","BaseDN": "<DC=contoso,DC=com>"},{"Server": "<contoso.server.com>","BaseDN": "<DC=defense,DC=contoso,DC=com>"}],"AuthType": "<Basic>","Login": "<Contoso>","Password": "<ContOso$123456789>","Filter": "<(objectclass=*)>","EnableSSL": "<true>"}}}The export creates two cookie files: ADExport_cookie_0.bin for the first BaseDN, and ADExport_cookie_1.bin for the second BaseDN, but the entries of both BaseDN properties will be written in ADExport_entries.csv.
Fulfill
This connector writes to the Active Directory, to create, update and delete entries, initiated manually through the UI or automatically by enforcing the policy. See the Evaluate Policy topic for additional information.
Configuration
The following example connects to an AD LDS system located at contoso.server.com.
<>need to be replaced with a custom value before entering the script in the command line.appsettings.agent.json{..."Connections": {..."ADFulfillment": {"Servers": [> {"Server": "<contoso.server.com>","BaseDN": "<DC=contoso,DC=com>"}],"AuthType": "Basic","AsAdLds": "true","EnableSSL": true,"Login": "<Contoso>","NoSigning": false,"Password": "<ContOso$123456789>",}}}
Setting attributes
| Name | Type | DescriptionDetails |
| AsAdLds optional | Boolean | True to state the managed system as an AD LDS. It isInfo: used for extracting the schema through the connection screen. |
| EnableSSL optional | Boolean | True to enable SSL protocol for authentication requests. NOTE: recommended when using AuthType set to Basic because basic authentication packets are not encrypted by default. SSL is not available on Linux. |
| Login optional | String | Login used by Identity Manager for basic authentication. NOTE: It is required when AuthType is set to Basic. |
| Password optional | String | Password used by Identity Manager for basic authentication. NOTE: It is required when AuthType is set to Basic. |
Output details
This connector can create a new resource, and update and delete an existing resource via the UI.
A new resource is created with the state disabled, corresponding to the useraccountcontrol value 514. When it is approved, its disabled state is removed and the useraccountcontrol value becomes 512.
Provision multiple forests
Same as for export, this connector can fulfill resources to multiple forests trusted by the same AD domain, by specifying the Server and BaseDN pairs in Servers for all forests.
The following example fulfills data to two targets: both on the same Server (contoso.server.com), but on two different BaseDNs (DC=contoso,DC=com and DC=defense,DC=contoso,DC=com).
"Connections": {
"ADFulfillment": {
"Servers": [{
"AsAdLds": "true"
Add attributes to the requests
Some systems using the LDAP protocol require additional attributes in the creation and/or update requests.
If these attributes are not synchronized in Identity Manager, then they cannot be computed and provided by scalar rules or navigation rules. In this case, they can be given as arguments in the provisioning order, through the ResourceType's ArgumentsExpression.
The following example adds the attribute description with a value depending on what is modified:
<ResourceType Identifier="LDAP_Entry_NominativeUser" DisplayName_L1="LDAP User (nominative)" Policy="Default" TargetEntityType="LDAP_Entry" Category="Accounts" SourceEntityType="Directory_User" ApprovalWorkflowType="One" HideOnSimplifiedView="true"
ArgumentsExpression="C#:resource:
var arguments = new System.Collections.Generic.Dictionary<string, string>();
if (provisioningOrder.HasChanged("cn")) {
arguments.Add("description", "This entry's login has been modified by Usercube.");
else if (provisioningOrder.HasChanged("mail")) {
arguments.Add("description", "This entry's email has been modified by Usercube.");
else {
arguments.Add("description", "This entry has been modified by Usercube.");
return arguments;">
<ScalarRule Property="givenName" Binding="FirstName" /> <ScalarRule Property="cn" Binding="Login" /> <ScalarRule Property="sn" Binding="LastName" /> <ScalarRule Property="employeeNumber" Binding="EmployeeId" /></ResourceType>
Password reset
See the appsettings.agent topic for additional information on how to configure password reset settings.
Credential protection
RSA encryption, configured in the appsettings.encrypted.agent.json file. See the RSA Encryption topic for additional information.
An Azure Key Vault safe; See the Azure Key Vault topic for additional information.
A CyberArk Vault able to store Active Directory's Login, Password and Server. See the CyberArk's AAM Credential Providers topic for additional information.
