EasyVista
This connector exports and fulfills users from/to an EasyVista-compliant system.
This page is about EasyVista .
EasyVista is an IT Service Manager that provides a service to organize IT resources in a company by using tickets. This allows users to manage projects, materials and teams through a customizable interface.
Prerequisites
- Reading first the appsettings.agent topic;
- An EasyVista account with reading/writing permissions on the target instance;
- A view to be created in EasyVista for each type of entity to export.
Export
This connector exports a list of users, with their attributes specified in the connector's configuration, to CSV files.
It can also export any custom entity, provided that a view exists for it in EasyVista.
Configuration
Connection in the UI and/or
the XML configuration, and in the appsettings.agent.json > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
- be unique.
- not begin with a digit.
- not contain
<,>,:,",/,\,|,?,*and_.
For example:
appsettings.agent.json{"Connections": {..."ExportEasyVista": {"Server": "https://easy-vista.instance.com/","Account": "11111","Login": "username","Password": "userPassword","ExportSettingsOptions": {"Profiles": "https://easy-vista.instance.com/api/v1/11111/internalqueries?queryguid={019B0523-F1C4-4G84-AA04-47BA16F16EB2}&filterguid={Z8A61D04-EZEC-42F1-A3E1-E9E09654BE68}&viewguid={2740V37A-A0ZC-4E50-A1F1-CF0987B9EFEA}"}}}}
The ExportSettingsOptions attribute is necessary only if custom entities are exported. It is not
required if only the users are exported.
Besides, "Profiles" is used here as an example and corresponds to a name to identify the exported
entities.
Setting attributes
| Name | Details |
| Server required | Type String Description URI of the server to connect to. |
| Account required | Type String Description Account to use to connect to the EasyVista instance. |
| Login required | Type String Description Username to use to connect to the EasyVista instance. |
| Password required | Type String Description Password to use to connect to the EasyVista instance. |
| ExportSettingsOptions optional | Type List Description List of entities to retrieve from the EasyVista instance. Note: for any customized entity to be exported, this argument must contain its REST API URL. Get REST API URLs Access the relevant view in EasyVista and click on ... > Rest API Url to copy the URL. For example: ![]() |
Output details
This connector is meant to generate to the Application Settings export output folder:
- a CSV file, named
<connectionIdentifier>_Employees.csv, with one column for each property having aConnectionColumnand each property without it but used in an entity association; - a CSV file for each customized entity, named
<connectionIdentifier>_<EntityName>.csv.
For example, with the following entity type mapping for employees:
<EntityType Identifier="EasyVista_User" DisplayName_L1="EasyVista User"> <Property Identifier="lastName" DisplayName_L1="lastName" TargetColumnIndex="0" Type="String" /></EntityType><EntityTypeMapping Identifier="EasyVista_User" Connector="ExportEasyVista" ConnectionTable="EasyVistaExport_Employees"> <Property Identifier="lastName" ConnectionColumn="last_name" /></EntityTypeMapping>And the following entity type mapping for profiles:
EntityType Identifier="EasyVista_Profiles" DisplayName_L1="EasyVista Profiles" Property Identifier="NAME_EN" DisplayName_L1="NAME_EN" TargetColumnIndex="23" Type="String" Type="String" IsKey="true" //EntityTypeEntityTypeMapping Identifier="EVProfiles" Connector="ExportEasyVista" ConnectionTable="EasyVistaExport_Profiles" Property Identifier="PROFILE_GUID">>>> ><<<<<<ConnectionColumn="PROFILE_GUID" IsPrimaryKey="true" / Property Identifier="NAME_EN" ConnectionColumn="NAME_EN" IsPrimaryKey="true" /></EntityTypeMapping>Then we will have
C:/identitymanagerContoso/Sources/EasyVistaExport_Employees.csvas follows:EasyVistaExport_Employees.csvlast_nameTalma BartTanner CarolTaverner DavidTaylor EricTelemann FranckThomson Georges...Then we will have
C:/identitymanagerContoso/Sources/EasyVistaExport_Profiles.csvas follows:EasyVistaExport_Profiles.csvNAME_EN, PROFILE_GUIDAdministration {value of the PROFILE_GUID}LOB Manager {value of the PROFILE_GUID}Product Team {value of the PROFILE_GUID}Project Manager {value of the PROFILE_GUID}...
Users created from the API are retrieved by Identity Manager only after a complete synchronization.
Fulfill
The EasyVista connector writes to EasyVista to create, archive (delete from Identity Manager's point of view) and update employees, initiated manually through the UI or automatically by reinforcing the policy. See the Evaluate Policy topic for additional information.
Configuration
For example:
appsettings.agent.json{..."Connections": {..."FulfillEasyVista": {"Server": "https://easy-vista.instance.com/","Account": "11111","Login": "username","Password": "userPassword"}}}
Setting attributes
| Name | Details |
Output details
This connector can:
Create and update employees and their profiles, but is limited by API limitations;
In particular, this connector cannot set dates nor the
employee_idproperty. -
Archive employees, i.e. set the
CONTRACT_END_DATEto the date of the fulfill execution.This action is performed when Identity Manager fulfills a provisioning order with a
Deletedchange type.
Authentication
Password reset
See the appsettings.agent topic to find out more on how to configure password reset settings.
Credential protection
Connection, configured in the
appsettings.encrypted.agent.jsonfile; -
Connection safe;
A CyberArk's AAM Credential Providers able to store EasyVista's
Login,Password,AccountandServer.
