SharedFolders
This connector exports users and permissions from Windows shared folders.
This page is about Shared Folders.
Also known as UFA (Identity Manager Folder Access), this connector can be used to scan the access rights assigned to folders and files in computers and networks which comply with the Windows File Security and Access Rights systems.
Prerequisites
Implementing this connector requires an account with the permissions:
to access all relevant folders and files and read their entitlements;
Log on as a batch job in the local group policy, when the connector's authentication mode is batch.
Export
This connector scans shared folders in order to export their content to CSV files.
Configuration
Connection in the UI and/or
the XML configuration, and in the appsettings.agent.json > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
- be unique.
- not begin with a digit.
- not contain
<,>,:,",/,\,|,?,*and_.
The following example reads
12levels of folders in the foldersR&D_ProjectsandManagementin the networkOfficeNetworkand inC:/. We only read entitlements about folders and we don't have access rights to the entitlements associated with the SIDsS-1-3-2-4andS-5-7-6-8. We use the service account account@example.com with its related password and domain, and interactive connection:appsettings.agent.json{..."Connections": {..."SharedFolderExport": {"InputDirectories": ["OfficeNetwork/R&D_Projects", "OfficeNetwork/Management", "C:/"],"OnlyDirectoryScan": "true","LevelOfScan": "12","ListOfSIDToAvoid": ["S-1-3-2-4", "S-5-7-6-8"],"Login": "account@example.com","Password": "accountexamplepassword","Domain": "Example","Interactive": true}}}
Setting attributes
| Name | Details |
| InputDirectories required | Type String List Description Paths of the folders to be scanned. |
| Domain optional | Type String Description Domain of the account used to access files and read their access rights. |
| Interactive default value: False | Type Boolean Description True to set authentication as interactive, False to set it as batch. |
| LevelOfScan optional | Type Int32 Description Number of file and folder levels to be scanned. By default, it scans the whole folder tree for each input directory. |
| ListOfSIDToAvoid optional | Type String List Description SIDs (users or groups) to exclude from the scan. |
| OnlyDirectoryScan default value: False | Type Boolean Description True to scan only folders' entitlements and not files', False to scan all. |
| Login optional | Type String Description Login of the account used to access the files and folders. Note: when not specified and Password neither, then the account running Identity Manager will be used. Note: if Domain is null, then Login must be set in the User Principal Name (UPN) format. |
| Password optional | Type String Description Password of the account used to access the files and folders. Note: when not specified and Login neither, then the account running Identity Manager will be used. |
Output details
This connector is meant to generate to the Application SettingsExport Output folder the following CSV files:
<connectionIdentifier>_ACE.csv, with the following columns:- key: concatenation of
Right,PathandOwnerSID; - Path: path of the folder or file;
- Right: entitlement among the following, listed from weakest to strongest: ListDirectory / ReadData / CreateFiles / WriteData / AppendData / CreateDirectories / ReadExtendedAttributes / WriteExtendedAttributes / ExecuteFile / Traverse / DeleteSubdirectoriesAndFiles / ReadAttributes / WriteAttributes / Write / Delete / ReadPermissions / Read / ReadAndExecute / Modify / ChangePermissions / TakeOwnership / Synchronize / FullControl
- AllowOrDeny:
0(orfalse) if the entitlement is allowed,1(ortrue) if it is denied; - OwnerSID: SID of the entitlement's owner.
<connectionIdentifier>_PathInformations.csv, with the following columns:- Path;
- ParentPath: path of the file's or folder's parent folder;
- BlockInheritance:
trueif the file or folder blocks entitlement inheritance in the tree; - Hierarchy: hierarchy in the scanned tree.
<connectionIdentifier>_SID.csv, with only one column SID.
Fulfill
There are no fulfill capabilities for this connector.
Authentication
Password reset
This connector does not reset passwords.
Credential protection
- Connection, configured in
the
appsettings.encrypted.agent.jsonfile; - An Connection safe;
| Attribute | Naming Convention for the Key in Azure Key Vault |
| Domain | Connections--<identifier>--Domain |
| Interactive | Connections--<identifier>--Interactive |
| LevelOfScan | Connections--<identifier>--MembersFile |
| ListOfSIDToAvoid | Connections--<identifier>--ListOfSIDToAvoid |
| Login | Connections--<identifier>--Login |
| OnlyDirectoryScan | Connections--<identifier>--OnlyDirectoryScan |
| Password | Connections--<identifier>--Password |
| InputDirectories | Connections--<identifier>--InputDirectories |
- A Connection able to store
Active Directory's
LoginandPassword.
Protected attributes are stored inside a safe in CyberArk, into an account whose identifier can be
retrieved by Identity Manager from appsettings.cyberark.agent.json.
For example:
appsettings.cyberark.agent.json{..."Connections": {..."SharedFolderExport": {"Login": "SharedFolderSettings","Password": "SharedFolderSettings"}}}
