Review an Unauthorized Account
How to remediate unauthorized accounts. The aim is to review the accounts whose assignments don't comply with the rules of the role model.
Unauthorized accounts are considered as non-conforming assignments because no rule from Identity Manager's model can justify their actual assignment to an identity.
| Input | Output |
| Provision (required) | Complying accounts |
Review an unauthorized account by proceeding as follows:
Ensure that the Compute Role Model Task was launched recently, through the complete job on the Job Execution page:
Or through the connector's overview page, Jobs > Compute Role Model.
Select
Unauthorized accountas theWorkflow State. Orphaned accounts appear with no owner.
Choose the default resource view or the property view with the top right toggle.
Click on the line of an account with an owner.
In the following example, the nominative LDAP account linked to the resource
U40897 / Internal Users / acme / comhas the ownerMaxime Guillotwith an 80% confidence rate.
The displayed confidence rate means that a rule actually assigned the account to the identity, but with a confidence rate too low to imply full automatic assignment. Approval will be required. See the Classify Resources topic for additional information.
The Resource Properties frame shows all the properties of the resources. They can be updated by clicking on the edit button. See the Reconcile a Property topic for additional information.
Select the appropriate decision.
Click on Confirm Account Deletion or Authorize Account according to the previous decision.
Trigger the Provision by launching, on the appropriate connector's overview page, Jobs > Generate Provisioning Orders, then, after this first task is done, Jobs > Fulfill.
Use property view
can be enabled by clicking on the Property View toggle at the top right corner.
Bulk keeping non-authorized accounts, by clicking on Bulk Reconcile then Approve Current Values, does not approve their unreconciled properties which will still be displayed on this screen.
Verify Review
In order to verify the process, check that the changes you ordered appear on the corresponding user's View Permissions tab.
