Google Workspace
This connector exports and fulfills users and groups from/to a Google Workspace instance.
This page is about Google Workspace .
Google Workspace provides a set of softwares and products developed by Google. The Google Workspace connector exports and fulfills users and groups from/to a Google Workspace instance. It exports user-group memberships too.
Prerequisites
reading first the appsettings.agentdocumentation;
a service account impersonating the following permission scopes: https://www.googleapis.com/auth/admin.directory. user and https://www.googleapis.com/auth/admin.directory.group.
See Google's documentation Google's documentation to create the service account with the right impersonation.
Remember, Google's documentation describes this procedure as optional, while the Google Workspace connector requires it.
Export
This connector extracts users, groups and user-group memberships from a Google Workspace instance, and write the output to CSV files.
Configuration
Connection in the UI and/or
the XML configuration, and in the appsettings.agent.json > Connections
section:
"Connections": {
"<ConnectionIdentifier>": {
- be unique.
- not begin with a digit.
- not contain
and_
For example:
"Connections": {
"GoogleExportFulfillment": {
"CredentialsFilePath": "C:/identitymanagerDemo/GoogleCredentials.json",
"User": "B29607@acme.internal",
"PageSize": "100"
Setting attributes
Name | Details |
CredentialsFilePath required | Type String Description Path of Google Workspace's JSON credentials file. See Google's documentation to create these credentials. |
User required | Type String Description Email address of the service account mentioned in the prerequisites section. |
PageSize default value: 50 | Type Int32 Description Number of items, i.e. users and/or groups and/or memberships, retrievable from Google Workspace by each API call (from 1 to 500). |
Output details
This connector is meant to generate to the Application SettingsExport Output folder the following CSV files:
GoogleExportFulfillment_Users.csv
andGoogleExportFulfillment_Groups.csv
whose headers come from the entity type mapping'sConnectionColumn
and from the entity association mappings' columns which are not members columns;GoogleExportFulfillment_Members.csv
with the following columns:- value: ID of the group;
- MemberId: ID of the group member.
If the connection column describes a sub-property, then the name should have the following pattern:
{property}:{sub-property}
. The character ":"
should not be used in other situations.
For example:
<EntityType Identifier="GOOGLE_Entry" DisplayName_L1="GOOGLE - Entry" DisplayName_L2="GOOGLE - Entree"> <Property Identifier="AgreedToTerms" DisplayName_L1="AgreedToTerms" Type="String" /> <Property Identifier="FamilyName" DisplayName_L1="FamilyName" Type="String" /></EntityType><EntityTypeMapping Identifier="GOOGLE_Entry" Connector="GOOGLE" ConnectionTable="GOOGLE_Users"> <Property Identifier="AgreedToTerms" ConnectionColumn="AgreedToTerms" /> <Property Identifier="FamilyName" ConnectionColumn="Name:FamilyName" /></EntityTypeMapping>Note that we have here
AgreedToTerms
which is a single property, andFamilyName
which is a sub-property ofName
, hence the nameName:FamilyName
as theConnectionColumn
Fulfill
This connector can write to Google Workspace to create, update, and/or delete users and user-group memberships.
Configuration
For example:
"Connections": {
Setting attributes
Name | Details |
Authentication
Password reset
This connector does not reset passwords.
Credential protection
This connector has no credential attributes, and therefore does not use RSA Encryption , nor a CyberArk's AAM Credential Providers Vault.
Still, data protection can be ensured through an Azure Key Vault safe.
