Home Folder
This connector exports home folders' content.
This page is about Home Folders .
Home Folders, also called Home Directory, is a user-dedicated storage area where users' personal files can be accessed. In general, a home folder is private so only its owner and administrators can access it. Moreover, the folders are often centralized because they are located on a network server. It allows making backups regularly and easily accessing the folders.
Prerequisites
- reading first how to Set, View, Change, or Remove Special Permissions and check the File and Folder Permissions list;
- an account with at least the special permission Read on all home folders in order to be able to export them.
Export
This connector exports all the home folders to a CSV file.
This connector performs only complete export, not incremental.
Configuration
Connection in the UI and/or
the XML configuration, and in the appsettings.agent.json > Connections
section:
"Connections": {
"<ConnectionIdentifier>": {
- be unique.
- not begin with a digit.
- not contain
and_
For example:
"Connections": {
"HomeFolderExport": {
"InputDirectories": [
"C:/ContosoFolder",
"C:/ContosoFolder2",
"Domain": "Windows",
"Interactive": true,
"Login": "Contoso",
"Password": "ContOso$123456789"
Setting attributes
Name | Details |
InputDirectories required | Type String List Description List of the directories that contain the home folders to be exported. |
Domain optional | Type String Description Domain of the account used to access the home folders. |
Interactive default value: False | Type Boolean Description True to set the authentication as interactive. False to set it batch. See Microsoft's documentation for more details. |
Login optional | Type String Description Login of the account used to access the files and folders. Note: when not specified and Password neither, then the account running Identity Manager will be used. Note: if Domain is null, then Login must be set in the User Principal Name (UPN) format. |
Password optional | Type String Description Password of the account used to access the files and folders. Note: when not specified and Login neither, then the account running Identity Manager will be used. |
Output details
This connector is meant to generate a CSV file, named <connectionIdentifier>.csv
,to the
Application SettingsExport
Output folder, with the following columns:
- Command: empty for now, as the connector performs only complete export.
- Name: name of the home folder.
For example, when exporting with a connection named
HomeFolderExport
, then the output file will be namedHomeFolderExport.csv
and will look like:HomeFolderExport.csv
Command,Name
Fulfill
There are no fulfill capabilities for this connector.
Authentication
Password reset
This connector does not reset passwords.
Credential protection
Connection , configured in the
appsettings.encrypted.agent.json
file; -
An Connection safe;
Connection able to store Home Folder's
Login
andPassword
