Microsoft Entra ID
This connector exports and fulfills user and groups from/to a Microsoft Entra ID (formerly Microsoft Azure AD) instance.
See the Microsoft Entra ID topic for additional information.
Microsoft Entra ID is Microsoft's cloud-based identity and access management service which helps your employees sign in and access resources in:
- External resources, such as Microsoft Office 365, the Azure portal, and thousands of other SaaS applications;
- Internal resources, such as apps on your corporate network and intranet, along with any cloud apps developed by your own organization.
Prerequisites
Implementing this connector requires giving Identity Manager application permissions, because Identity Manager does not access the Microsoft Graph API on behalf of a user but with its own identity, and delegated permissions are not enough. These application permissions require the consent of an administrator of the target Microsoft Entra ID tenant.
See theRegister for Microsoft Entra ID topic on how to register Identity Manager as an application with the Microsoft Identity Platform in order to grant Identity Manager a service account which authenticates with the target Microsoft Entra ID.
Export
For a configured set of directory objects on an Microsoft Entra ID instance, this connector exports the list of configured attributes in the associated entity type mapping to a CSV file.
Configuration
This process is configured through a connection in the UI and/or the XML configuration. See the Connection topic for additional information.
Or in the appsettings.agent.json > Connections
section:
script in the command line.
"Connections": {
"<ConnectionIdentifier>": {
NOTE: The identifier of the connection and thus the name of the subsection must:
- be unique
- not begin with a digit
- not contain
and_
For example:
"Connections": {
"MicrosoftEntraIDExport": {
"ApplicationId": "<contosoAzure897>",
"ApplicationKey": "<25d408a1925d4c081925b\d40819>",
"TenantId": "<25d40819-f23f-4837-9d50-a9a52da50b8c>",
"MicrosoftGraphPathApi": "<https://graph.microsoft.com/beta/>",
"ResponseUri": "<https://agent.usercubecontoso.com>"
Setting attributes
The table below summarizes the setting attributes of Microsoft Entra ID connector.
Name | Type | Description |
ApplicationId (required) | String | GUID that uniquely identifies the application registration in the Azure tenant. NOTE: The value obtained at registration: App registrations > Owned applications > Identity Manager > Overview > Application (client) ID |
ApplicationKey (required) | String | Secret associated with the ApplicationId NOTE: The value obtained at registration: App registrations > Owned applications > Identity Manager > Certificate & secrets > Client secrets > Client Secret |
TenantId (required) | String | GUID that uniquely identifies the Azure tenant. NOTE: The value obtained at registration: App registrations > Owned applications > Identity Manager > Overview > Application (tenant) ID |
ResponseUri (default value: http://localhost ) | String | URI used by Azure to contact back the application with the tokens. This response Uri needs to be registered in the app registration. |
MicrosoftAuthorityPath (optional) | String | Pattern for Microsoft Authority Path. |
MicrosoftGraphPath (default value: https://graph.microsoft.com/.default) | String | Scope requested to access a protected API. NOTE: For this flow (client credentials), the scope should be of the form {ResourceIdUri/.default} . See Microsoft's documentation for additional information. |
MicrosoftGraphPathApi (default value: https://graph.microsoft.com/v1.0/ ) | String | Microsoft Graph Uri API. |
Output details
This connector is meant to generate the following files:
<connectionIdentifier>_directoryobjects.csv
containing the property values from the entity type mapping associated with the connection.NOTE: The values are exported from the entities listed in the attribute
C0
of theEntityTypeMapping
.For example, with the following configuration:
need to be replaced with a custom value before entering the script in the command line.
<EntityTypeMapping Identifier="MicrosoftEntraID_DirectoryObject" Connector="MicrosoftEntraID" ConnectionTable="MicrosoftEntraIDExport_directoryobjects" C0="user group directoryRole servicePrincipal">
<Property Identifier="accountEnabled" ConnectionColumn="accountEnabled" />
<Property Identifier="objectid" ConnectionColumn="id" IsPrimaryKey="true" />
<Property Identifier="mail" ConnectionColumn="mail" />
</EntityTypeMapping>Four entities are exported (
user
;group
;directoryRole
;servicePrincipal
) and whose names are to be found in the column@odata.type
. ThenMicrosoftEntraIDExport_directoryobjects.csv
looks like:MicrosoftEntraIDExport_directoryobjects.csv
Command,@odata.type,accountEnabled,id,mail
...Remember, attributes described as "Supported only on the Get
<entity_name>
API" in the Microsoft Graph API documentation cannot be retrieved through this connector. The export task will raise an error if these attributes are used in your EntityTypeMapping.This connector supports Microsoft Entra ID Schema Extensions but does not support Microsoft Graph Schema Extensions.
<connectionIdentifier>_<navigationProperty>_<entity>.csv
describing the navigation property from one entity to another.For example
AzureADExport_members_group.csv
would look like:MicrosoftEntraIDExport_members_group.csv
Command,groupId,id
...Where command can be
insert
,update
ordelete
; groupId is the id of the group; id is the id of the group member (in this context).NOTE: Only the navigation properties
members
andowners
are exported. These navigation properties are automatically detected according to the data exported. -
one file
<connectionIdentifier>_cookie_<entity>.bin
per entity, containing an URL with adelta token
useful for incremental export.For example
MicrosoftEntraIDExport_cookie_user.bin
Remember, most exports can be run in complete mode, where the CSV files will contain all entries, or in incremental mode, where CSV files will contain only the entries which have been modified since the last synchronization.
A task can use the IgnoreCookieFile boolean property, and a command line (with an executable) can use the option --ignore-cookies.
The CSV files are stored in the Export Output folder, and the cookie file in the Export Cookies folder. See the Application Settings topic for additional information.
For more details, see Microsoft's documentation on columns and attributes synchronized to Microsoft Entra ID.
Fulfill
This connector writes to the Microsoft Entra ID, to create, update and delete Microsoft Entra ID objects, initiated manually through the UI or automatically by enforcing the policy. See the Evaluate Policy topic for additional information.
Configuration
For example:
"Connections": {
"MicrosoftEntraIDFulfillment": {
"ApplicationKey": "<84468d65324ghj\de9864d3d7e89026>",
"ResponseUri": "<https://agent.usercube.com>"
Setting attributes
The table below summarizes the setting attributes.
ApplicationId required | String | GUID that uniquely identifies the application registration in the Azure tenant. NOTE: value obtained at registration: App registrations > Owned applications > Identity Manager > Overview > Application (client) ID |
ApplicationKey required | String | Secret associated with the ApplicationId . NOTE: value obtained at registration: App registrations > Owned applications > Identity Manager > Certificate & secrets > Client secrets > Client Secret |
TenantId required | String | NOTE: GUID that uniquely identifies the Azure tenant. value obtained at registration: App registrations > Owned applications > Identity Manager > Overview > Application (tenant) ID |
ResponseUri default value: http://localhost | String | URI used by Azure to contact back the application with the tokens. This response Uri needs to be registered in the app registration. |
MicrosoftGraphPathApi default value: https://graph.microsoft.com/v1.0/ | String | Microsoft Graph Uri API. |
Output details
This connector can create a new resource, update and delete any Microsoft Entra ID objects and groups' memberships via the UI.
Authentication
See the following to figure out authentication.
Password reset
See theappsettings.agent topic for additional information on how to configure password reset settings.
Credential protection
RSA Encryption , configured in the
appsettings.encrypted.agent.json
file -
An Azure Key Vault safe;
A CyberArk's AAM Credential Providers Vault able to store Microsoft Entra ID's
ApplicationId
andApplicationKey
