Microsoft Exchange
This connector exports mailboxes from a Microsoft Exchange instance.
This page is about Microsoft Exchange .
Package: Server/Microsoft Exchange
Microsoft Exchange Server is Microsoft's email, calendar, contact, scheduling and collaboration platform. It is deployed on the Windows Server operating system (OS) for business use. This connector uses Exchange Server PowerShell (Exchange Management Shell) to export databases and mailboxes.
Prerequisites
Export
This connector exports mailboxes and mailbox databases. Two CSV files are generated, one with the mailbox properties (like Database, EmailAddresses, ServerName , etc.) and the other with mailbox database properties (like Name, Server, Mounted, etc.). These properties are explicitly part of the PowerShell script used by Identity Manager.
Configuration
This process is configured through a Connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
  • be unique.
  • not begin with a digit.
For example:
"Connections": {
"MicrosoftExchangeExport": {
"AuthType": "Kerberos",
"Server": "http://mailbox01.contoso.com/PowerShell/"
Setting attributes
NameDetails
Server requiredType String Description Address of the Exchange Server used by the remote PowerShell: http://<ServerFQDN>/PowerShell/ where <ServerFQDN> is the fully qualified domain name of the Exchange server, like mailbox01.contoso.com.
PowerShellScriptPath default value: {your usercube path}/Runtime/Export-Exchange.ps1Type String Description Path of the export script file.
Output details
This connector is meant to generate the following files:
  • <connectionIdentifier>_mailboxes.csv with the following columns:
    <connectionIdentifier>_databases.csv
    Command,Database,EmailAddresses,UseDatabaseRetentionDefaults,RetainDeletedItemsUntilBackup,DeliverToMailboxAndForward,ExchangeGuid,ExchangeUserAccountControl,ForwardingAddress,ForwardingSmtpAddress,IsMailboxEnabled,ProhibitSendQuota,ProhibitSendReceiveQuota,RecoverableItemsQuota,RecoverableItemsWarningQuota,CalendarLoggingQuota,IsResource,IsLinked,IsShared,SamAccountName,AntispamBypassEnabled,ServerName,UseDatabaseQuotaDefaults,UserPrincipalName,WhenMailboxCreated,IsInactiveMailbox,AccountDisabledIsDirSynced,Alias,OrganizationalUnit,DisplayName,MaxSendSize,MaxReceiveSize,PrimarySmtpAddress,RecipientType,RecipientTypeDetails,Identity,IsValid,Name,DistinguishedName,Guid,ObjectCategory,WhenChangedUTC,WhenCreatedUTC,ObjectState
    Insert,value1,value2,...,valueN
    For example, we could have C:/identitymanagerContoso/Temp/ExportOutput/MicrosoftExchangeExport_mailboxes.csv.
    See more details on mailbox properties in Microsoft's documentation.
  • <connectionIdentifier>_databases.csv with the following columns:
    Command,Name,Server,Mounted,ObjectCategory,Guid,WhenChangedUTC,WhenCreatedUTC,ObjectState
    See more details on mailbox database properties in Microsoft's documentation.
  • <connectionIdentifier>_cookie.bin which stores the time of the last successful export, thus allowing incremental processes.
The CSV files are stored in the Application SettingsExport Output, and the cookie file in the Export Cookies folder.
Fulfill
This connector can create, update or delete mailboxes' addresses (PrimarySmtpAddress, ProxyAddress) and mailbox databases.
As it works via a PowerShell script. See the PowerShellProv topic for additional information.
Identity Manager's PowerShell script can be found in the SDK in Usercube.Demo/Scripts/Fulfill-Exchange.ps1.
Authentication
Authentication Type
This connector uses Kerberos authentication when trying to connect with the Exchange Server.
Password reset
This connector does not reset passwords.
Credential protection
This kind of credential protection can be used only for the export process.
The fulfill process' credentials can be protected by following the instructions for the PowerShellProv connector. See the PowerShellProv topic for additional information
