PowerShellSync
This connector exports data from an external system via a PowerShell script.
This page is about PowerShellSync .
Package: Custom/PowerShellSync
PowerShell is a cross-platform task automation and configuration management framework, consisting of a command-line shell and scripting language. Unlike most shells which accept and return text, PowerShell is built on top of the .NET Common Language Runtime (CLR), and accepts and returns .NET objects. This fundamental change brings entirely new tools and methods for automation.
Data can be synchronized from any managed system by writing a PowerShell script that generates the relevant CSV files for Identity Manager. The PowerShellSync connector provides all the necessary tools for an easy integration of the script with Identity Manager's synchronization mechanisms.
When Identity Manager provides a native connector for a given system, for example the Active Directory connector, Netwrix Identity Manager (formerly Usercube)highly recommends using the native connector rather than this PowerShell connector.
Prerequisites
  • making sure that the command powershell.exe, inside the command prompt (cmd.exe), does execute a PowerShell terminal;
  • knowledge of scripting in PowerShell 5.1 or later, see here PowerShell's requirements;
  • making sure that the device hosting the agent has its execution policy properly configured to execute the given PowerShell script;
  • checking the targeted system's requirements (environment, libraries, etc.), as this connector is meant to connect Identity Manager to a PowerShell-compatible system;
  • writing and testing a PowerShell script (.ps1) according to Netwrix Identity Manager (formerly Usercube)' guidelines below.
Export
This connector executes a PowerShell script that generates one or several CSV files. These files are to be used during the synchronization of the data from the managed system targeted by the PowerShellSync connector.
The CSV files must be written to the $OutputPath.
The export is executed by a job from the UI, or via Usercube-Export-Powershell.exe in the command prompt.
Configuration
This process is configured through a Connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
  • be unique.
  • not begin with a digit.
For example:
"Connections": {
"PowerShellExport": {
"PowerShellScriptPath": "C:/identitymanagerDemo/Scripts/Export-CSV.ps1",
Setting attributes
NameDetails
PowerShellScriptPath requiredType String Description Path of the PowerShell script (.ps1) to be executed.
Write a script
Identity Manager provides a few variables to be used in the PowerShell script.
| Name | Details | | ------------- | -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- | --------------------------------------------------------------------------------------------------------------------- | | OutputPath | Type String Description Prefix of the path of the generated CSV file. Info: the synchronization process requires the generated CSV file to be located in a very specific location, with a specific name prefix. Hence the need for this predefined variable. Value <TempFolderPath>/ExportOutput/<connectionIdentifier>_ Example In this example, if the temp folder is named Temp and the connection PowerShellExport, then the generated file is: Temp/ExportOutput/PowerShellExport_users.csv. generateCSV | Export-CSV ($OutputPath + "users.csv")` where`generateCSV is a generic PowerShell method that generates CSV files. | | IsIncremental | Type Boolean Description Variable to be used to provide a different behavior for complete and incremental synchronization. |
Fulfill
There are no fulfill capabilities for this connector.
