SAP Netweaver
This connector exports and fulfills users and roles from/to an SAP Netweaver instance.
This page is about SAP S/4 HANA .
Package: ERP/SAP S/4 HANA
SAP ERP is an enterprise resource planning software developed by the German company SAP SE. The software incorporates the key business functions of an organization. ERP software includes programs in all core business areas, such as procurement, production, materials management, sales, marketing, finance, and human resources (HR).
Prerequisites
  • reading first the appsettings.agentdocumentation;
  • a service account with reading and writing permissions on the SAP server.
Export
This connector exports users, roles, role memberships and groups from an SAP instance and writes the output to CSV files.
Configuration
This process is configured through a Connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
  • be unique.
  • not begin with a digit.
For example:
"Connections": {
"SAPExportFulfillment": {
"Server": "serverUrl",
"Login": "login",
"Password": "password"
Setting attributes
NameDetails
Server requiredType String Description URL of the SAP server.
Login requiredType String Description Login to authenticate to the specified server.
Password requiredType String Description Password to authenticate to the specified server.
Output details
This connector is meant to generate to the Application SettingsExport Output folder the following CSV files:
  • sap_users.csv with the following columns:
    sap_users.csv
    Command,logonname,isserviceuser,firstname,lastname,salutation,title,jobtitle,mobile,displayname,description,email,fax,locale,timezone,validfrom,validto,lastmodifydate,islocked,isaccountlocked,ispasswordlocked,ispassworddisabled,telephone,department,id,securitypolicy,datasource,company,streetaddress,city,zip,pobox,country,state,orgunit,accessibilitylevel,passwordchangerequired
    Insert,value1,value2,...,valueN
  • sap_groups.csv with the following columns:
    sap_groups.csv
    Command,uniquename,displayname,description,lastmodifydate,id,datasource,distinguishedname
  • sap_roles.csv with the following columns:
    sap_roles.csv
    Command,uniquename,displayname,description,lastmodifydate,id,datasource,scopes,actions
  • sap_roles_member.csv with the following columns:
    Command,id,member
Fulfill
This connector writes to SAP to create, update, and/or delete users, groups, roles and group memberships.
Configuration
Setting attributes
NameDetails
For example:
"Connections": {
"Login": "login",
Authentication
Password reset
See the appsettings.agent topic to learn more on how to configure password reset settings.
When setting a password for an SAP user, the password attribute is defined by the password specified in the corresponding Resource Type Mappings.
Credential protection
AttributeNaming Convention for the Key in Azure Key Vault
ServerConnections--<identifier>--Server
LoginConnections--<identifier>--Login
PasswordConnections--<identifier>--Password
  • A Connection able to store Active Directory's Login, Password and Server.
Protected attributes are stored inside a safe in CyberArk, into an account whose identifier can be retrieved by Identity Manager from appsettings.cyberark.agent.json.
For example:
"Connections": {
"Login": "SAPExportFulfillment_CyberArkKey",
"Password": "SAPExportFulfillment_CyberArkKey",
"Server": "SAPExportFulfillment_CyberArkKey"
