ServiceNow
This connector exports and fulfills any data, including users and roles, from/to a ServiceNow CMDB.
This page is about ServiceNow .
ServiceNow is a cloud-based company that provides software as a service (SaaS) for technical
management support. The company specializes in IT service management (ITSM), IT operations
management (ITOM) and IT business management (ITBM), allowing users to manage projects, teams and
customer interactions via a variety of apps and plugins.
This section focuses on ServiceNow Entity Management. To learn about how to use this connector to
create tickets for other resources, see
ServiceNow Ticket .
Prerequisites
- reading first the appsettings documentation;
- a service account with the snc_platform_rest_api_access role, as well as reading and writing permissions on the target ServiceNow instance;
- the version ServiceNow London or later;
- the appropriate configuration in ServiceNow of authentication, Basic or OAuth.
Export
This connector exports to CSV files ServiceNow's tables (Users, Groups, Group Memberships).
An incremental search is possible to retrieve added and updated records but a full delta (including deleted items) can't be performed.
Configuration
Connection in the UI and/or
the XML configuration, and in the appsettings.agent.json > Connections
section:
"Connections": {
"<ConnectionIdentifier>": {
- be unique.
- not begin with a digit.
- not contain
and_
The following example retrieves from users only those that are active, and no filter is applied to the other tables. A single request can retrieve up to 5,000 entries, no more. This means that if there are 6,000
sys_user
to retrieve, then all of them will be retrieved but with two requests.appsettings.agent.json
"Connections": {
"ServiceNowExportFulfillment": {
"Server": "https://instance.service-now.com/api/now/table",
"Login": "login",
"Password": "password",
"ResponseSizeLimit":"5000",
"Filter":"sys_user#active=true"
}The following example is the same as above, but using OAuth Authentication:
"Connections": {
"Login": "login",
"ClientId": "ClientId",
"ClientSecret": "ClientSecret",
"OAuth2Url": "https://instance.service-now.com/oauth_token.do",
Setting attributes
Name | Details |
Server required | Type String Description URL of the ServiceNow Server Table API endpoint. See ServiceNow Official API Reference. Info: the URL must start with https . |
Login required | Type String Description Username of the service account used to connect to the server. |
Password required | Type String Description Password of the service account used to connect to the server. |
ClientId optional | Type String Description Client Id used (and required) with OAuth. |
ClientSecret optional | Type String Description Client Secret used (and required) with OAuth. |
OAuth2Url optional | Type String Description Application endpoint used (and required) with OAuth. |
Output details
This connector is meant to generate to the
Application SettingsExport
Output folder one CSV file for each table, named <connectionIdentifier>_<tableName>.csv
Identity Manager lists the tables to retrieve based on Entity Type Mapping 's and Entity Association Mapping 's connection tables.
For the connector to work properly, the connection tables must follow the naming convention too:
For example, with the following configuration:
<EntityTypeMapping Identifier="User" Connector="ServiceNow" ConnectionTable="ServiceNowExportFulfillment_sys_user"> <Property Identifier="sys_id" ConnectionColumn="sys_id" IsPrimaryKey="true" /> <Property Identifier="name" ConnectionColumn="name" /> <Property Identifier="user_name" ConnectionColumn="user_name" /> <Property Identifier="email" ConnectionColumn="email" /></EntityTypeMapping><EntityTypeMapping Identifier="User" Connector="ServiceNow" ConnectionTable="ServiceNowExportFulfillment_sys_group"> <Property Identifier="sys_id" ConnectionColumn="sys_id" IsPrimaryKey="true" /> <Property Identifier="name" ConnectionColumn="name" /> <Property Identifier="description" ConnectionColumn="description" /></EntityTypeMapping><EntityAssociationMapping Identifier="Group_Members" Column1="user" EntityPropertyMapping1="User:sys_id" Column2="group" EntityPropertyMapping2="Group:sys_id" Connector="ServiceNow" ConnectionTable="ServiceNowExportFulfillment_sys_user_grmember" C0="sys_user_grmember"
/>We would have:
ServiceNowExportFulfillment_sys_user.csv
sys_id,active,name,user_name,email
...ServiceNowExportFulfillment_sys_group.csv sys_id,name,description ...
ServiceNowExportFulfillment_sys_user_grmember.csv
user,group
Fulfill
This connector writes to ServiceNow to create, update, and/or delete any data.
Configuration
For example:
"Connections": {
"Login": "login",
"Connections": {
"Login": "login",
Setting attributes
Name | Details |
Authentication
Password reset
See the appsettings.agent topic to learn more on how to configure password reset settings.
When setting a password for an ServiceNow user, the password attribute is defined by the password specified in the corresponding Resource Type Mappings.
Credentials protection
- Connection , configured in
the
appsettings.encrypted.agent.json
file; - An Connection safe;
Attribute | Naming Convention for the Key in Azure Key Vault |
Server | Connections--<identifier>--Server |
Login | Connections--<identifier>--Login |
Password | Connections--<identifier>--Password |
ClientId | Connections--<identifier>--ClientId |
ClientSecret | Connections--<identifier>--ClientSecret |
OAuth2Url | Connections--<identifier>--OAuth2Url |
Filter | Connections--<identifier>--Filter |
ResponseSizeLimit | Connections--<identifier>--ResponseSizeLimit |
- A Connection able to store
Active Directory's
Login
,Password
,Server
,ClientId
andClientSecret
Protected attributes are stored inside a safe in CyberArk, into an account whose identifier can be
retrieved by Identity Manager from appsettings.cyberark.agent.json
For example:
"Connections": {
"Login": "ServiceNowExportFulfillment_CyberArkKey",
"Password": "ServiceNowExportFulfillment_CyberArkKey",
"Server": "ServiceNowExportFulfillment_CyberArkKey",
"ClientId": "ServiceNowExportFulfillment_CyberArkKey",
"ClientSecret": "ServiceNowExportFulfillment_CyberArkKey"
