ServiceNowTicket
This connector opens tickets in ServiceNow for manual provisioning.
This page is about ServiceNow Ticket .
ServiceNow is a cloud-based company that provides software as a service (SaaS) for technical
management support. The company specializes in IT service management (ITSM), IT operations
management (ITOM) and IT business management (ITBM), allowing users to manage projects, teams and
customer interactions via a variety of apps and plugins.
This section focuses on ServiceNow ticket creation for the fulfillment of resources that can't or
shouldn't be performed with an existing fulfill. To learn about how to manage entities, see
ServiceNow Entity Management.
Prerequisites
- reading first the appsettings.agentdocumentation;
- a service account with the snc_platform_rest_api_access role, as well as reading and writing permissions on the target ServiceNow instance;
- the version ServiceNow London or later;
- the appropriate configuration in ServiceNow of authentication, Basic or OAuth.
Export
This connector exports some of ServiceNow entities, see the export capabilities of the ServiceNow connector. Some entities cannot be exported.
Fulfill
This connector writes to ServiceNow to create incident and request tickets containing information to create, update or delete a resource. It does not create nor update a resource directly.
Once created, the ticket is managed in ServiceNow, not in Identity Manager.
When the ticket is closed or canceled, Identity Manager updates the provisioning state of the resource accordingly. See the Entitlement Assignment topic for additional information.
See the fulfill capabilities of the ServiceNow connector.
For example:
appsettings.agent.json
"Connections": {
"ServiceNowFulfillManual": {
"Server": "https://instance.service-now.com/api/now/table",
"Login": "login",
"Password": "password"
Authentication
Password reset
See the appsettings.agent topic to learn more on how to configure password reset settings.
When setting a password for a ServiceNow user, the password attribute is set to the chosen value and
the user's password_needs_reset attribute is set to true
Credential protection
- Connection , configured in
the
appsettings.encrypted.agent.json
file; - An Connection safe;
Attribute | Naming Convention for the Key in Azure Key Vault |
Server | Connections--<identifier>--Server |
Login | Connections--<identifier>--Login |
Password | Connections--<identifier>--Password |
ClientId | Connections--<identifier>--ClientId |
ClientSecret | Connections--<identifier>--ClientSecret |
OAuth2Url | Connections--<identifier>--OAuth2Url |
TicketCookieDirectoryPath | Connections--<identifier>--TicketCookieDirectoryPath |
ResponseSizeLimit | Connections--<identifier>--ResponseSizeLimit |
- A Connection able to store
Active Directory's
Login
,Password
,Server
,ClientId
andClientSecret
Protected attributes are stored inside a safe in CyberArk, into an account whose identifier can be
retrieved by Identity Manager from appsettings.cyberark.agent.json
For example:
"Connections": {
"Login": "ServiceNowFulfillManual_CyberArkKey",
"Password": "ServiceNowFulfillManual_CyberArkKey",
"Server": "ServiceNowFulfillManual_CyberArkKey",
"ClientId": "ServiceNowFulfillManual_CyberArkKey",
"ClientSecret": "ServiceNowFulfillManual_CyberArkKey"
