Quick Start Guide
This guide leads the reader through the steps to quickly install Identity Manager's bootstrap version.
Prerequisites
The installation of Identity Manager requires:
A certificate named Usercube.pfx (see the Microsoft tool to create a self-signed certificate)
If the certificate is named something other than Usercube.pfx, remember to change the name in the Runtime/appsettings.json file too.
Database-related specifications
Install the Bootstrap Version
Step 1 – Go on the Netwrix Identity Manager (formerly Usercube) portal and download the artifacts of the expected version.
Step 2 – Extract from SDK the folder Identity Manager Bootstrap anywhere on the computer.
Step 3 – Extract the content of Runtime to Identity Manager Bootstrap.
When extracting Identity Manager Bootstrap to the root of the computer, it looks like:
Step 4 – Move or copy your certificate inside the Runtime folder.
Step 5 – Create a Sources folder in Identity Manager Bootstrap.
Remember, if you don't have the Identity Manager Bootstrap folder or if you don't create the Sources folder, the Path in the Directory connection in the Runtime/appsettings.agent.json must be adapted. Note that you don't need to have a Directory.xlsx file at the location described by this Path for now.
Step 6 – Create a database named Identity Manager, using the default options.
When using a database server other than Microsoft SQL Server or a different database name, remember to change the connection string accordingly, in the Runtime/appsettings.json file and in the future command lines.
Step 7 – Execute the Runtime/identitymanager.sql file in the database.
Step 8 – Open a command prompt and deploy the configuration. See the Usercube-Deploy Configuration topic for additional information.
In our example, the command would be, in the Runtime folder:
script in the command line.
./identitymanager-Deploy-Configuration.exe -s "<data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;>" -d "<C:/identitymanagerBootstrap/Conf>"
Step 9 – Launch the server. See the Usercube-Server topic for additional information.
In our example, the command would be, still in the Runtime folder:
./identitymanager-Server.exe
Step 10 – Open a browser and navigate to http://localhost:5000. Authenticate with administrator as a username and the password specified in the Runtime/appsettings.json file, in the Authentication section.
Now you can start using the application.
Next Steps
From there, you can start setting up Identity Manager via the Settings page which is accessible from the Configuration section of the home page.
Then, Netwrix Identity Manager (formerly Usercube) recommends following the user guide to start the configuration of your IGA project from scratch. See the User Guide topic for additional information.
