Set Up Incremental Synchronization
How to implement an incremental synchronization Job for a given Connector via XML, to upload the related system's resources to Identity Manager.
See an example on For Microsoft Entra ID (formerly Microsoft Azure AD).
Netwrix Identity Manager (formerly Usercube) strongly recommends configuring as much as possible via the UI instead of XML files. See how to Synchronize Data via the UI.
Prerequisites
First read how to Create a Connector.
Build the Incremental Synchronization Job
Identity Manager provides a fully-written standardized job to perform incremental synchronization through the UI. See here:
See how to launch incremental Synchronize Data via the UI.
Any IGA action is configured through Job.
Synchronization jobs contain tasks that are to be executed on agent side.
Components
Any synchronization job should include:
- export;
- synchronization preparation;
- synchronization.
The export is configured and performed by the Export Task, the synchronization preparation by the Prepare Synchronization Task and the synchronization by the Synchronize Task.
See the Upward Data Synchronization topic for additional information.
Identity Manager provides a scaffolding that generates the configuration for these steps, named Create Connector Synchro Incremental.
This guide is about incremental synchronization, but complete synchronization can be configured with the Create Connector Synchro Complete scaffolding.
Permissions for the agent
In order to launch a job via the Usercube-Invoke-Job tool, the agent must use a profile with the right permissions for each task.
Permissions within Identity Manager are configured through Access Control Rule.
For example:
Conf/Profile AgentJob.xml
<Profile Identifier="AgentSynchro" DisplayName_L1="Agent Synchro" />
Netwrix Identity Manager (formerly Usercube) recommends the creation of a profile for synchronization jobs, and another for provisioning jobs, in order to comply with the principle of least privilege.
In order to run a synchronization job, the agent requires the permissions to:
- view the tasks via
/Jobs/Task/Query; - access progress reports via
/Jobs/JobInstance/Query,/Jobs/JobInstance/Update,/Jobs/TaskInstance/Queryand/Jobs/TaskInstance/Update; - prepare the synchronization and synchronize via
/Connectors/Connector/Queryand/Connectors/SynchronizeSession.
Identity Manager provides scaffoldings that generate the configuration for granting these permissions: SynchronizationAccessControlRules and Job View Access Control Rules.
The following example permits the
AgentSynchroprofile to run any synchronization job:
Conf/Profile AgentSynchro.xml
<SynchronizationAccessControlRules Profile="AgentSynchro"><JobViewAccessControlRules Profile="AgentSynchro">``
Agent's authentication to the server
Every request from agent to server within the execution of a job needs to be authenticated with an OpenIdClient Connect ClientId/Secret pair.
So first, the configuration must contain a ClientId/Secret pair.
Usable ClientId/Secret pairs are configured through an
OpenIdClient.
The following example uses a secret hashed by Usercube-New-OpenIDSecret:
Conf/OpenIdClients.xml
<OpenIdClient Identifier="Job" HashedSecret="K7gNU3sdo+Op8wNhqoVWhr5v6s1xYv72ol/pe/Unols=" DisplayName_L1="ClientId for Jobs" Profile="Administrator" />``
Then, the agent's profile must be linked to one of the ClientId/Secret pairs.
Agents' settings are configured in their appsettings.agent.json file.
The following example sets the
Job/secretpair to be used by tasks and jobs:
{ ... "OpenId":{ "OpenIdClients": { "Job": "secret" }, "DefaultOpenIdClient": "Job" } }``
Permissions for users
In order to launch the job, a user must have the right permissions.
In order to launch a synchronization job, a user requires the appropriate permission:
/Jobs/RunJob/Launch.
Identity Manager provides a Job Execution Access Control Rules that generates the configuration for granting this permission.
For example:
<JobExecutionAccessControlRules Profile="AgentSynchro">``
Schedule the Job
Scheduling the job execution can rely either on Identity Manager's scheduler or on an external scheduler.
Using scheduler
Identity Manager's scheduler is configured through the
Job's CronTabExpression property.
See Crontab documentation for more details.
Using an external scheduler
An external scheduler relies on using an external mechanism to schedule the Usercube-Invoke-Job.exe.
Validate the Job
Validate the job's execution by proceeding as follows:
- Deploy the XML configuration to the database, by using the Deploy Configuration Task.
- In the UI, access the Job Execution page from the dashboard's Administration section.
- Find the job named with the string specified in the XML configuration in the job's
DisplayNameproperty, and launch it. - Once the job is completed, the system's objects should be synchronized to the database's
UR_Resourcestable.
