Connection to the Database
The connection of Identity Manager's server to the database is set through the appsettings
top-level ConnectionString and the AzureCredentials attributes:
| Name | Details |
| ConnectionString required | Type String Description Identification token used to retrieve the connection information for the server to access Identity Manager's database in SQL Server. Note: must be compliant with SQL Server connection string syntax. See the Install the Server topic for additional information. Example{ � "ConnectionString": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" } |
| ConnectionStringGovernor required | Type String Description Identification token used to retrieve the connection information to SQL Server Resource Governor which is a feature used to manage SQL Server's workload and system resource consumption. Info: Resource Governor enables specifying limits on the amount of CPU, physical I/O, and memory that incoming application requests can use. Note: must be compliant with SQL Server connection string syntax. See the Install the Server topic for additional information. Note: all tasks and jobs use this connection string, when specified. Example{ � "ConnectionStringGovernor": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" } |
| AzureCredentials required | Type Azure Credentials Description Settings used with the ConnectionString to access the database in SQL Server, hosted on Microsoft Entra ID (formerly Microsoft Azure AD). |
AzureCredentials
The database can be accessed one of two ways:
either by specifying
User Idandpasswordkeywords directly in the connection string:For example:
"ConnectionString": "data source=.;Database=UsercubeContoso;User
Id=UsercubeServerContoso;Password=myPassword;Min Pool Size=10;encrypt=false;" -
or, to avoid exposing the
User Idandpasswordin a connection string sent through the network, by using the built-in Microsoft Entra ID authentication method:For example:
"ConnectionString": "Server=tcp:<server-name>.database.windows.net,1433;Initial
Catalog=<database-name>;Persist Security
Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;"
See Microsoft's documentation for more details about authentication methods
The following example authenticates with ClientId and ClientSecret:
appsettings.json
{ ... "ConnectionString": "Server=tcp:.database.windows.net,1433;Initial Catalog=;Persist Security
Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;",
"AzureCredentials": { "ClientId": "", "AADTenantId": "", "ClientSecret": "" } }
The following example authenticates with a pfx-stored public key certificate (password-protected pfx archive):
appsettings.json
"AzureCredentials": { "ClientId": "", "AADTenantId": "", "EncryptionCertificate": { "File": "",
"Password": "" } } }
| Name | Details |
| ClientId optional | Type String Description Client ID obtained from Microsoft Entra ID when registering Identity Manager as an application. |
| AADTenantId optional | Type String Description Microsoft Entra ID's tenant identifier obtained when registering Identity Manager as an application. Note: remember to set Identity Manager as owner of the targeted database when registering Identity Manager as an application in Microsoft Entra ID. |
| ClientSecret optional | Type String Description Microsoft Entra ID's client secret used by Identity Manager to authenticate.Note: used only if EncryptionCertificate is not specified. |
| EncryptionCertificate required, if ClientSecret is not defined | Type Encryption Certificate Description Location of the certificate used by Identity Manager to authenticate, instead of the ClientSecret. |
