Restrict the Assignment
Create a Dimension
The restriction of resource allocations is done from a filter. To do this, it is necessary to create a Dimension to define which EntityTypes the filters will apply to.
Create a Single Role
To be able to filter with the dimensions previously created, it is necessary to first create Single Role which will serve as a restriction to the assignment of ResourceTypes for a given source.
<SingleRole Identifier="DL-INTERNET-Restricted" DisplayName_L1="Filtered Internet access" DisplayName_L2="Acces Internet filtre" Category="Internet" ApprovalWorkflowType="One" EntityType="Directory_User" Policy="Default" />
Assign the Role Based on the Dimension
We will define a Single Role Rule on the "Title"; dimension with a given value to restrict the allocation of a resource in only one case.
**<SingleRoleRule Role="DL-INTERNET-Restricted" D1="FCT0402" Policy="Default" />**
**<Dimension Identifier="Title0" DisplayName_L1="Title" DisplayName_L2="Fonction" EntityType="Directory_Title" ColumnMapping="1" />**
Assign a Resource Type Based on the Role
The restriction on the creation of these accounts is integrated directly into the type rule of the Resource Type. This implies that the ResourceType will only apply if the Single Role Rule are checked.
This part will link a SingleRole to a ResourceType. This implies that the allocation of a target resource to a source will only be done if the SingleRole rule(s) are verified.
</ResourceType>
Use a navigation rule instead of a type rule
A Resource Type in addition to filling a multi-valued association, also serves as an allocation context for a ResourceType.
- Fill in one or more dimensions directly in the NavigationRule.
- Fill in a SingleRole.
- Fill in one or more dimensions and a SingleRole.
In the example above the ResourceType does not need a TypeRule because the NavigationRule already serves as an allocation context.
