Thresholds
Thresholds are essential safety guards controlling all changes, for example preventing the overwriting of important data by mistake.
Thresholds are by default activated to warn users when synchronization or provisioning triggers too many modifications. If the number of modifications exceeds the specified threshold, Identity Manager stops the synchronization/provisioning and displays a warning on the log page.
Thresholds can be deactivated via the value 0, though they should not all be. Each action must be
"guarded" by at least one threshold.
Once the changes have been reviewed, the blocked job can be resumed (or not). See the Synchronize Data topic for additional information.
As long as a synchronization job is blocked for a connector, the export, prepare-synchronization and synchronization tasks of this connector are removed from incremental jobs. The synchronization is unblocked as soon as the blocked job is resumed, or as soon as a job involving the connector is launched in complete mode.
Thresholds for Synchronization
Synchronization thresholds can be configured in XML files via:
Entity Type Mapping to count the number of resources impacted by synchronization inside a given entity type. They are configured with:
Absolute Threshold Relative Threshold MaximumDeletedLinesMaxPercentageDeletedLinesMaximumInsertedLinesMaxPercentageInsertedLinesMaximumUpdatedLinesMaxPercentageUpdatedLines -
Entity Association Mapping to count the number of navigation properties impacted by synchronization inside a given entity type. They are configured with:
Absolute Threshold Relative Threshold MaximumLinkDeletedLinesMaxLinkPercentageDeletedLinesMaximumLinkInsertedLinesMaxLinkPercentageInsertedLines -
Connector to count the number of resources and/or navigation properties impacted by synchronization inside all entity types of a given connector. They are configured with:
Absolute Threshold Relative Threshold Resources MaximumDeletedLinesMaxPercentageDeletedLinesMaximumInsertedLinesMaxPercentageInsertedLinesMaximumUpdatedLinesMaxPercentageUpdatedLinesNavigation Properties MaximumLinkDeletedLinesMaxLinkPercentageDeletedLinesMaximumLinkInsertedLinesMaxLinkPercentageInsertedLines
All thresholds are active. Therefore, the lowest threshold (according to the specific situation) would be the first to stop synchronization.
For example, in a connector, the default values for thresholds are 100 modifications for resources
(Maximum...Lines) and 1000 modifications for navigation properties (MaximumLink...Lines).
If we launch synchronization for an entity type whose threshold values are lower than the connector's, then Identity Manager blocks synchronization as soon as the number of modifications exceeds the entity type's threshold values.
If the entity type's threshold values are higher than the connector's, then Identity Manager blocks synchronization as soon as the number of modifications exceeds the connector's threshold values (100 resources or 1000 navigation properties).
Distinct Thresholds are configurable for provisioning.
