Notification Aspect
Sends a notification email to one or several users.
Examples
The following example sends a notification email based on the template
Notification_Directory_Guest.cshtml and the subject computed by SubjectExpression_L1, which both
use data from Workflow_Directory_Guest:Directory_Guest, and on the styles from
Notification_Directory_Guest.css.
<NotificationAspect Identifier="Notification_Directory_Guest" ExpressionBinding="Workflow_Directory_Guest:Directory_Guest" RazorFile_L1="./Templates/Notification_Directory_Guest.cshtml" CssFile="./Templates/Notification_Directory_Guest.css" SubjectExpression_L1="C#:guest:return "Validating data for guest: " + guest.FirstName + guest.LastName;">
<PointCut Activity="Directory_Guest_AdvancedStart:Request" ActivityState="ActionWithRefine-Executed" Mode="After" /> <Recipient Type="Binding" Binding="Directory_Guest:Mail" /></NotificationAspect>
The notification will be sent after the Request activity of the Directory_Guest_AdvancedStart
workflow is executed.
The notification will be sent to all email addresses defined by Directory_Guest:Mail.
Properties
| Property | Details |
| Identifier required | Type String Description Unique identifier of the aspect. |
| Binding optional | Type String Description Binding whose difference with ExpressionBinding defines the property that corresponds to identities' email addresses, when Type is set to Binding. |
| CssFile optional | Type String Description Path to the css file that defines the styles for the email. Note: the path must be relative to the configuration folder, and the file must be inside it. |
| ExpressionBinding optional | Type String Description Binding: - that defines the variable type used in the potential expressions specified in the aspect; - whose difference with Binding defines the property involved in the aspect. Note: required when handling the property of multi-valued objects, for example records, to make sure to modify the property in all records and not only in one. |
| Priority default value: 0 | Type Int32 Description Execution priority among all aspects. At a given activity state, the aspect with the highest priority will be triggered first. Note: the priority can be a negative value. |
| RazorFile_L1 optional | Type String Description Path to the Razor cshtml file that defines the email's body template in language 1 (up to 16). Note: the path must be relative to the configuration folder, and the file must be inside it. |
| SubjectExpression_L1 optional | Type String Description C# expression that defines the email's subject in language 1 (up to 16). The expression's variable type is defined in ExpressionBinding. |
Child Element: PointCut
A pointcut is a mechanism telling Identity Manager when to execute the linked Aspects.
The position of the pointcut is specified by an activity state and a mode (before or after).
| Activity required | Type Int64 Description Identifier of the activity whose specified state triggers the aspect. |
| ActivityState required | Type Enumeration Description Identifier of the activity state that triggers the aspect. |
| Mode default value: 0 | Type PointCutMode Description Mode defining when exactly the aspect is triggered around the specified workflow's activity state. 0 - Before: the aspect will be executed on entry to the specified activity state, regardless of the transition used. 1 - After: the aspect will be executed on exit from the specified activity state, regardless of the transition used. |
Child Element: Recipient
A recipient defines one or several identities who will receive a notification from
NotificationAspect.
Examples
The following example sends a notification email to the actors of the next step of the workflow.
<NotificationAspect Identifier="Notification_Directory_User" ExpressionBinding="Workflow_Directory_User:Directory_User" RazorFile_L1="Template/Notification_Directory_User.cshtml" CssFile="Template/Notification_Directory_User.css"> <PointCut Activity="Directory_User_StartInternal:Request" ActivityState="ActionWithRefine-Executed" Mode="After" />
<Recipient Type="Actor" />
The following example sends a notification email to the performers of the Request activity of the
Directory_User_StartInternal workflow when the state is Executed.
<Recipient Type="Performer" Activity="Directory_User_StartInternal:Request" ActivityState="ActionWithRefine-Executed" />
The following example sends a notification email to the email address, stored in Mail, of the
user(s) from Directory_User targeted by the workflow, so here the new user created by the
Directory_User_StartInternal workflow.
<Recipient Type="Binding" Binding="Directory_User:Mail" />
The following example sends a notification email to all identities whose email addresses are defined
as {lastName}@company.com.
<Recipient Type="Expression" Expression="C#:user:return user.LastName+"@company.com";" />
The following example sends a notification to all identities with a profile that includes the right permission.
<NotificationAspect Identifier="Directory_User_New" ExpressionBinding="Workflow_Directory_User:Directory_User" RazorFile_L1="Directory/User/Directory-User-Notification-New.cshtml" CssFile="Notifications.css"> <PointCut Activity="Directory_User_NewInternal:Persist" ActivityState="Persist-Invoked" Mode="After" /> <PointCut Activity="Directory_User_NewExternal:Persist" ActivityState="Persist-Invoked" Mode="After" />
<Recipient Type="Profile" />
Knowing that we also have:
<Profile Identifier="Workforce/Notifications/Directory_User_New" DisplayName_L1="Workforce/Notifications/New User" IsComponent="true" /><AccessControlRule Profile="Workforce/Notifications/Directory_User_New" EntityType="Directory_User" Identifier="Composite_Notifications_Directory_User_New*" DisplayName_L1="Composite_Notifications_Directory_User_New*">
<Entry Permission="/Custom/WorkflowsNotifications/Directory_User_NewInternal/Persist/Invoked" /> <Entry Permission="/Custom/WorkflowsNotifications/Directory_User_NewExternal/Persist/Invoked" />
</AccessControlRule>
| Activity optional | Type Int64 Description Identifier of the activity whose last performers are to be notified, when Type is set to Performer. Note: must be set together with ActivityState. |
| ActivityState optional | Type Enumeration Description Identifier of the activity state whose last performers are to be notified, when Type is set to Performer. Note: must be set together with Activity. |
| Binding optional | Type Int64 Description Binding of the property that represents the notification's recipients, when Type is set to Binding. |
| EmailAddresses optional | Type String Description Email addresses of the notification's recipients, when Type is set to Hardcoded. |
| Expression optional | Type String Description C# expression that returns the email addresses of the notification's recipients, as strings or IEnumerable<string>, when Type is set to Expression. The expression's variable type is defined in ExpressionBinding in the associated NotificationAspect. See the Expressions topic for additional information. |
| IsCC default value: false | Type Boolean Description true to send the notification email to the recipient(s) as a carbon copy (CC). |
| Type required | Type RecipientType Description Type of recipients for the email notification. Actor: the identities with the permissions to act on the next step of the workflow specified in the pointcut. Performer: the actors of a past workflow step specified in Activity and ActivityState. Binding: the identities whose email addresses are designated by the property specified in Binding. Hardcoded: the identities whose email addresses are specified explicitly in EmailAddresses. Expression: the identities whose email addresses match the C# expression specified in Expression. Profile: the identities with the permission /Custom/WorkflowsNotifications/{workflow_identifier}/ {activity_identifier}/{activityTemplateState_shortIdentifier}. |
