Migration Guide
This guide is designed to provide step-by-step procedures in order to migrate Identity Manager from your current version to the latest one.
For the latest SaaS versions, if you are using the administrator scaffolding the necessary permissions for the update are added to the administrator scaffolding and they will be taken into account the next time the configuration is deployed.
General Upgrade Instructions for the Server with Integrated Agent
Step 1 – Download the usercube-server-runtime from the expected version from
Netwrix Portal.
Step 2 – Stop the existing server.
Step 3 – Rename the Runtime folder to create a backup, for example RuntimeOld.
Step 4 – Extract the content of the new Runtimeto the same folder as RuntimeOld, inside a
new Runtime folder.
Step 5 – Copy the original appsettings.json and appsettings-agent.json files from
RuntimeOld to the new Runtime.
Step 6 – Restart the server.
General Upgrade Instructions for the Agent
Step 1 – Download the usercube-agent-runtime from the expected version from
Netwrix Portal.
Step 2 – Stop the existing agent.
new Runtime folder.
Step 5 – Copy the original web.config, appsettings.json and appsettings-agent.json files
from RuntimeOld to the new Runtime.
Step 6 – Restart the agent.
Specific Information to Migrate from v6.1 to vsaas
If you are looking to upgrade the Netwrix Identity Manager version from 6.1 to saas you will not need to take any action because the database will automatically be upgraded. If you have problems importing your configuration into saas related to C# expressions, please run the Identity Manager-Check-ExpressionsConsistency tool. See the Usercube-Check-ExpressionsConsistency topic for additional information.
Specific Information to Migrate from v6.0 to v6.1
If you are looking to upgrade the Netwrix Identity Manager version from 6.0 to 6.1 you will not need to take any action because the database will automatically be upgraded.
