Indirect Permissions
Identity Manager can compute, for a given identity, permissions that are obtained implicitly or indirectly through assignments. The Compute Role Model Task is responsible for this functionality.
Assigning a role to a user can give them new permissions in a managed system by giving access to a new role or a new group, for example. This assignment is direct as it is entirely explicit. However, the user might also receive some additional permissions that are inherited through the new permission and that are not explicit. For instance in some systems, users can get permissions by being a member of a group but groups can also be members of other groups, and therefore allow for transitive permission acquisitions. These permissions are called indirect. This notion can also be extended when permissions in a managed system also give other permissions in an external system.
Indirect Permissions are automatically computed by the Compute Role Model Task along with standard explicit or direct permissions during a full update. Indirect permissions will not be computed when processing a single user (for instance through "Repair Data (helpdesk)") or during simulations.
Configuration
The computation of Indirect Permissions is based on the configured Indirect Resource Rule . These rules tell Identity Manager how to navigate the managed system and how to recover permissions that a user inherits implicitly. An Indirect Resource Rule is composed of the following properties:
ResourceType
—The Resource Type to which the rule will be applied.Property
— The Entity Type which corresponds to the user permission in the target system.Correspondence
(optional)— The Entity Type that is used to recover the correspondence of a resource from the target system in the external system.CorrespondenceMembershipProperty
(optional) — The Entity Type which corresponds to the user permission in an external system.Entitlement
(optional) — The Entity Type that can be configured if the permission in the external system needs to be recovered from the discovered resources. For instance one can use this property to recover the entitlements of Sharepoint groups (whileCorrespondenceMembershipProperty
will be used to recover the group membership graph).
If either Correspondence
or CorrespondenceMembershipProperty
is specified, then the other
property must be specified as well.
If Entitlement
is specified, then both Correspondence
and CorrespondenceMembershipProperty
also need to be specified.
TargetEntityTypeProperty
— The Entity Type which identifies each rule given a resource type.TargetEntityTypeReflexiveProperty
— The Entity Type which corresponds to the user permission in the target system.IndirectResourceBinding
— The Bindings that is used to recover an assignment from a permission in either system (target or external). It is also used to define the correspondence between resources in both systems.IndirectResourceReflexiveProperty
(optional): The Entity Type which corresponds to the user permission in an external system.
Correspondences between resources are necessarily one-sided: the Indirect Permissions computation is started in the managed system and if a correspondence is found, the computation will be continued in the external system. Correspondences won't be checked in the external system.
An example of an Indirect Resource Rule configuration is available in How-To: Configure Indirect Permissions in an Active Directory.
What Can Be an Indirect Permission?
The Compute Role Model Task will create indirect Assigned Resource Navigations for the permissions that it finds, but if and only if these permissions are associated with a Resource Type.
If a Single Role is associated with one of these Resource Navigation Rules, then an indirect Single Role will also be recovered.
Finally, if at least one indirect Single Role is used to recover a Composite Role , then the Composite Role will also be indirect.
What Can Be Done with Indirect Permissions?
Currently, Indirect Permissions are only displayed and found in the users' View Permissions
tab in
the Advanced View
: Indirect Permissions (except Composite Roles) are hidden in the
Simplified View
Although Indirect Permissions are marked as Non-conforming
, they can be neither approved nor
deleted. They also won't appear in Access certification campaigns.
Indirect Permissions are always indicated by the following icon:
Disabling the Indirect Permission Computation
In case of emergency, one can disable the computation of indirect permissions by adding the
"DisableIndirectPermissions": true
field to the root of the appsettings
. While the computation
is disabled, indirect permissions will be frozen in time: any existing one will not be deleted and
any potential new one will not be added.
