Built-in Users Group Permissions
Question
During the security assessment in the Netwrix Access Analyzer environment, the use of the Users group (S-1-5-32-545) was noted for Access Analyzer services and folders. Does Netwrix Access Analyzer require the use of the Users group?
Answer
The use of the Users group is not required—Netwrix Access Analyzer implements the Users group by default. You can modify the permissions for the installation folder to exclude the group. Refer to the following path for the default installation folder for Access Analyzer:
C:\Program Files (x86)\STEALTHbits\StealthAUDIT\
Refer to the following article for additional information on Role Based Access to the Netwrix Access Analyzer console: https://docs.netwrix.com/docs/auditor/10_8 (Access — Role Based Access · v11.6).
