Using SQL Style Credentials in Access Analyzer
Summary
Summary: How to use SQL Style Credentials in Netwrix Access Analyzer
Issue
Issue: Instructions for using SQL style credentials
Instructions
Instructions: If SQL style credentials for the ODBC or SQL data collector are needed then
  1. Use the domain type of in the connection profile
  2. Enter the rest of the credentials as normal.
Be sure to set the connection profile directly on the job.
  • (Right click job > Properties > Connection tab > bottom radio option)
Module
Module: Credentials/Access; Netwrix Access Analyzer - Connection Profile/Credentials
Salesforce Article ID: 000001102
