Clearing FSAA Certificates for the Netwrix Enterprise Auditor FSAA Proxy Scanner Service
Related Queries
- "How do I clean up FSAA certificates if the proxy is running as LocalSystem?"
- "Uninstalling Netwrix FSAA Proxy Scanner – what should I do with certificates?"
- "FSAA troubleshooting – trust issues and certificates"
- "Need to remove old FSAA service account certificates"
This article explains how to clear certificates used by the Netwrix Enterprise Auditor FSAA Proxy Scanner Service (FSAA Proxy Service). These certificates may reside in the local machine or user certificate stores, depending on the account the service is running under.
You may need to perform this cleanup for one or more of the following reasons:
- Uninstalling or decommissioning the FSAA Proxy Service
- Changing the service account associated with the FSAA Proxy
- Replacing or rotating certificates due to trust relationship changes
- Troubleshooting connectivity or authentication issues related to certificate usage
- Using NAA v11.6.0.65 or earlier | NAA File System Proxy v11.6.0.19 or earlier
Before beginning, determine which account the FSAA Proxy Scanner service is running as by looking for the Log On As account in Windows Services for the Netwrix Enterprise Auditor FSAA Proxy Scanner service. If running as LocalSystem, elevated access methods are required to remove certificates from the user profile for that account.
Instructions
Option 1 – Service Is Running as a Service Account
- Move
FSAACertificateManager.exefrom%SAInstallDir%\PrivateAssemblies\FILESYSTEMACCESS\Appletto the FSAA Proxy Server. - Open Command Prompt as the service account used by FSAA Proxy.
- Run the following commands one by one:
cd C:\Path\to\FSAACertificateManager
.\FSAACertificateManager.exe -clearCertificatesFromStore -store Server -Location LocalMachine
.\FSAACertificateManager.exe -clearCertificatesFromStore -store Client -Location LocalMachine
.\FSAACertificateManager.exe -clearCertificatesFromStore -store CertificateAuthority -Location LocalMachine
Option 2 – Service Is Running as LocalSystem (Using PsExec)
- Move
FSAACertificateManager.exeto the FSAA Proxy Server. - Install PSTools (PSExec) onto the FSAA Proxy Server from Microsoft | PSTools.
- Run:
psexec -s -i cmd.exe
- In the new console window, navigate to the tool's location:
cd "C:\Path\to\FSAACertificateManager"
- Run the following:
.\FSAACertificateManager.exe -clearCertificatesFromStore -store Server -location CurrentUser
.\FSAACertificateManager.exe -clearCertificatesFromStore -store Client -location CurrentUser
.\FSAACertificateManager.exe -clearCertificatesFromStore -store CertificateAuthority -location CurrentUser
Option 3 – LocalSystem Without PsExec (Using Scheduled Task)
- Move
FSAACertificateManager.exeto the FSAA Proxy Server. - In PowerShell, run:
$action = New-ScheduledTaskAction -Execute "FSAACertificateManager.exe" -Argument "-clearCertificatesFromStore -store Server -location CurrentUser" -WorkingDirectory "C:\Path\to\FSAACertificateManager"
$principal = New-ScheduledTaskPrincipal -UserId "NT AUTHORITY\SYSTEM" -LogonType ServiceAccount -RunLevel Highest
Register-ScheduledTask -TaskName "CleanFSAACerts" -Action $action -Principal $principal
Start-ScheduledTask -TaskName "CleanFSAACerts"
Start-Sleep -Seconds 5
Unregister-ScheduledTask -TaskName "CleanFSAACerts" -Confirm:$false
- Repeat the process for
ClientandCertificateAuthoritystores.
Option 4 – LocalSystem Without PsExec or Scheduled Tasks (Registry Deletion)
- Open PowerShell as Administrator on the FSAA Proxy Server.
- Run the following to delete certificates directly from the registry:
$systemStores = @(
"HKLM:\SOFTWARE\Microsoft\SystemCertificates\FSAA Certificate Authority Store",
"HKLM:\SOFTWARE\Microsoft\SystemCertificates\FSAA Server Certificate Store",
"HKLM:\SOFTWARE\Microsoft\SystemCertificates\FSAA Client Certificate Store"
foreach ($store in $systemStores) {
if (Test-Path $store) {
Remove-Item -Path $store -Recurse -Force
Write-Host "Removed certificates from $store"
$systemUserStore = "Registry::HKEY_USERS\S-1-5-18\Software\Microsoft\SystemCertificates"
$fsaaStores = @("FSAA Certificate Authority Store", "FSAA Server Certificate Store", "FSAA Client Certificate Store")
foreach ($storeName in $fsaaStores) {
$path = Join-Path $systemUserStore $storeName
if (Test-Path $path) {
Remove-Item -Path $path -Recurse -Force
Write-Host "Removed $storeName from SYSTEM user profile"
Option 5 – Create a Temporary Service for Cleanup
- Move
FSAACertificateManager.exeto the FSAA Proxy Server. - In Command Prompt, run:
sc.exe create FSAACertCleanup binPath= "cmd.exe /c \"cd /d \"C:\Path\to\FSAACertificateManager\" && FSAACertificateManager.exe -clearCertificatesFromStore -store Server -location CurrentUser\"" type= own start= demand
sc.exe start FSAACertCleanup
timeout /t 3 /nobreak >nul
sc.exe delete FSAACertCleanup
- Repeat for
ClientandCertificateAuthoritystores as needed.
