Netwrix Access Analyzer: Migrating Low Priority Scheduled Tasks to Normal Priority to Improve Job Performance
Summary
In some cases, Scheduled Tasks in Netwrix Access Analyzer are created with priority 7 (Below Normal) instead of 5 (Normal), or with no priority set at all. This results in StealthAUDIT.exe I/O to/from Tier 2 databases being Low Priority which could lead to reduced performance. This article outlines how to migrate Scheduled Tasks to be Priority 5 rather than Priority 7 via PowerShell.
Instructions
Important:
  • The credential in the script below is not for permission purposes. Rather, it is the Service Account that will be assigned to each modified Scheduled Task.
  • This script should be run again any time a new Netwrix Access Analyzer Scheduled Task is created.
  1. Run the script below in an elevated PowerShell on the Netwrix Access Analyzer server (or download the script here: https://netwrix.com/download/products/KnowledgeBase/SA-ScheduledTaskPriority.ps1):
param (
[Parameter(Mandatory=$true)][PSCredential]$TaskServiceAccount
$currentPrincipal = New-Object Security.Principal.WindowsPrincipal([Security.Principal.WindowsIdentity]::GetCurrent())
if (-not $currentPrincipal.IsInRole([Security.Principal.WindowsBuiltInRole]::Administrator)) {
Write-Error "Script must be Run As Admin. Exiting..."
exit
$directories = @("C:\Windows\System32\Tasks", "C:\Windows\Tasks")
$directories | ForEach-Object {
$list = Get-ChildItem $_ | `
Where-Object { $_.name -like "SAJOB*" } | `
Select-Object Name
$list | ForEach-Object {
$taskName = $_.Name
$task = Get-ScheduledTask -TaskName $taskName
$task.Settings.Priority = 5
Set-ScheduledTask `
-TaskName $taskName `
-Action $task.Actions `
-Settings $task.Settings `
-User $TaskServiceAccount.Username `
-Password $TaskServiceAccount.GetNetworkCredential().Password
  1. Confirm the script ran successfully by observing output. It should look similar to the example below:
TaskPath                                       TaskName                          State
\ SAJOB~.Active Directory Invent... Ready
\ SAJOB~FSAA~{A5142820-4190-4244... Ready
\ SAJOB~SEEK~{3ABDD931-37EB-4734... Ready
  1. Observe XMLs for scheduled tasks in C:\Windows\Tasks or C:\Windows\System32\Tasks and confirm priority is now set to 5 (Normal).
After successfully running the script all Netwrix Access Analyzer Scheduled Tasks will now run with Normal I/O priority.
