How To Add the Jobs for a Newly Licensed Solution to an Existing Application Installation
This article explains how to add jobs for a newly licensed solution to an existing Netwrix Access Analyzer installation. You can use one of the two methods described below after applying the new license file.
NOTE: For instructions on how to apply a new license key to Netwrix Access Analyzer, please visit: How to Update the License Key in Access Analyzer.
Instructions
Add Solution via Instant Solutions
  1. Open the Netwrix Access Analyzer console, right-click the Jobs folder, and select Add Instant Job.
  2. In the Instant Job Wizard, expand Library Name: Instant Solutions by clicking the + icon. Instant Solutions library with newly licensed module selected
  3. Select the newly licensed module (e.g., .Active Directory Inventory), then click Next.
  4. On the Summary page of the Instant Job Wizard, select Save & Exit.
    Summary page of Instant Job Wizard with Save & Exit button highlighted
  5. Your newly licensed module should now appear in the Netwrix Access Analyzer Job Tree.
Add Solution via File Explorer
  1. With the Netwrix Access Analyzer console closed, navigate to the Instant Solutions folder in Netwrix Access Analyzer's installation directory (%SAInstallDir%InstantSolutions).
    Instant Solutions folder in installation directory
  2. Locate the GROUP_ folder for the new solution and copy it to the Jobs folder (%SAInstallDir%Jobs).
    • Example: Adding the Windows Solution
      • To: %SAInstallDir%Jobs\GROUP_Windows
  3. Launch Netwrix Access Analyzer, and your newly licensed module should now appear in the Netwrix Access Analyzer Job Tree.
NOTE: For further details on job configuration, see Netwrix Access Analyzer Solutions Overview.
  • How to Update the License Key in Access Analyzer
  • Netwrix Access Analyzer Solutions Overview
