How to Troubleshoot a Failed Job Execution
This article describes how to troubleshoot a failed job execution in Netwrix Auditor.
Instructions
  • Check Job Stats.
    • In the console expand the Job > Status Node and Select the Job Stats Table. This will allow you to verify if a failure is a one-time occurrence or a recurring issue.
  • Check Job TaskStats.
    • In the console, expand Job > Status Node and select the Task Stats Table. Tthis will allow you to verify if all job components are failing or just specific tasks.
  • Check Runstats.ini.
    • Right-click the job and select the Explore folder option.
    • Open the runstats_prev.ini in a plain-text editor.
    • Check the run statistics for the previous saved runs (five is the default in the application settings node).
  • Check Server Uptime.
    • Open Task Manager.
    • Select the Performance tab.
    • Check server uptime. If server uptime is greater than 30 days, make sure that there are no MSFT patches with pending reboots.
  • Check Job Log.
    • Right-click on the job and select the Explore folder option.
    • Enter the output folder and locate a file named in the following fashion:
      • JobName_log.tsv (Example: the first job in the tree should be 1-AD_Scan for the .Active Directory Inventory group. The log for this job will be named 1-AD_Scan_log.tsv)
    • Review any messages leading up to end of file or leading up to end of processing for a given host:
      • Search for the failed host name.
      • Search for the words ERROR or WARNING and select the match case option.
    • Get the timestamp of the last line in file.
  • Check SQL Server uptime and service uptime.
  • Check Windows Event Logs around that time. Look for errors and warnings that could indicate failure.
    • Application (e.g., crash)
    • Security (e.g., logoff)
  • Check Task Scheduler history (Task Scheduler Event Log).
  • Check Netwrix Auditor Event Log (%sainstalldir%logs).
  • Check SADebug Logs:
    • Application
    • JobEngine
      • These logs are found in both the SADatabase Folder and in the root of the installation directory (%sainstalldir%sadatabase).
  • Check Applet/Agent logs (e.g., FSAA, SPAA On-Prem, Exchange Metrics, PowerShell). These logs are found in various places:
    • ExchangePS engine - %sainstalldir%Private Assemblies\Folders identified by query GUID and job runtime
    • PowerShell Applet - %sainstalldir%jobs\SA_CommonData\PowerShell
    • SQL DC - %sainstalldir%jobs\SA_CommonData\SQLDC
    • Smartlog Applet - %sainstalldir%jobs\SA_CommonData\SmartLog
    • FSAA Applet - C:\Program Files(x86)\STEALTHbits\StealthAUDIT\FSAA\HOST
