Blank Reports in Access Analyzer Web Console
Symptom
The published reports in the Web Console of Netwrix Access Analyzer show blank pages. Searching by a report name allows you to run a report.
Causes
- The SQL Server instance times out due to the preexisting query. This issue might arise in larger environments with higher loads.
- The Reports folder is corrupted.
Resolutions
Remove the Solution.xml file
The Solution.xml file queries SQL for a summary of audited systems, and it might be timing out depending on the loads in your environment. Removing it allows the reports to populate in a timely manner.
- In the Netwrix Access Analyzer host, navigate to
Installation_Folder\STEALTHbits\StealthAUDIT\Jobs\GROUP_NAME. - Remove the
Solution.xmlfile.
Recreate the Reports folder
If the prior resolution did not help, follow these steps:
- In Netwrix Access Analyzer, navigate to the Reporting node.
- Review the path to the Reports folder in the Publish Reports: field. The default path is
C:\Program Files (x86)\STEALTHbits\StealthAUDIT\Reports. - In the Netwrix Access Analyzer host, recreate the Reports folder.
