Could Not Drop Object Referenced by Foreign Key Constraint
Symptom
When you run the SP_DropTables job, the job fails and prompts the following error:
Could not drop object %table_name% because it is referenced by a foreign key constraint.
Cause
The affected tables reference the foreign key constraint preventing the SP_DropTables job from running correctly.
Resolution
Manually release the constraints for the affected tables.
  1. In SQL Server Management Studio, run the following line to output associated foreign key constraints. The example shows the SA_SPAC_ActivityEvents table—replace it with the table mentioned in the error message.
EXEC sp_fkeys 'SA_SPAC_ActivityEvents'
  1. The results will contain the FKTABLE_NAME column—run the following line to release the corresponding constraint. The example shows the SA_SPAC_ActivityEvents foreign key. Run the line with each FKTABLE_NAME specified in the results.
DROP TABLE SA_SPAC_GroupMembershipChanges
  1. After releasing the constraints, rerun the SP_DropTables job.
