Error: Sequence Contains More Than One Matching Element
Symptom
When running a job in Netwrix Access Analyzer that generates a report, the report generation fails with the error:
Sequence contains more than one matching element.
Cause
Duplicate entries in the %sainstalldir%\Reports\report.xml file lead to the report failing to populate, as it cannot be determined which field is correct.
Report Configuration Example
<Reports>
<Report>
<Id>{F5BE87EC-11E4-4779-93C9-462DB92F68E4}</Id>
<Name>Attribute Changes</Name>
<Version>3</Version>
<Author>Netwrix Corporation</Author>
<Published>true</Published>
<Generated>Monday, January 27, 2025 5:00 PM</Generated>
<Description>This report tracks attribute changes within Active Directory.</Description>
<Tags />
</Report>
<Report>
<Tags />
</Report>
</Reports>
Resolution
To resolve this issue, follow these steps:
  1. Open the %sainstalldir%\Reports\report.xml file in a text editor.
  2. Locate and remove all duplicate entries for the job causing the error. I. Copy the line that begins and ends with <Id> and </Id>. Search the file for this line.
    II. Remove any duplicates of the corresponding <Report></Report> section.
  3. Save the file.
  4. Run the job again to generate the report.
<Reports>
<Report>
<Tags />
</Report>
</Reports>
