Sequence Contains More Than One Matching Element Error on Schedules Tab After Upgrading to 12.x
Applies To​
  • Product: Netwrix Access Analyzer (formerly Enterprise Auditor)
  • Versions affected: Upgrade from 11.6 to 12.x. For product documentation, see Netwrix Access Analyzer 12.0.
NOTE: Cause 2 does not depend on an upgrade. The error can also occur on 12.0 without an upgrade from 11.6 if a job folder is copied into the Jobs directory.
Symptom​
After upgrading Netwrix Access Analyzer from version 11.6 to 12.x, opening the Schedules tab in the Access Analyzer console fails with an error similar to:
Failed to get tasks…
Failed to initialize task SAJOB~<JobGroupName>~<GUID>…
Error: Sequence contains more than one matching element.
The <JobGroupName> in the error message identifies which job group contains the duplicated entry (e.g., SG_LocalAdmins).
NOTE: The same error text also appears when a job generates a report. For that cause, see Report Generation Error: Sequence Contains More Than One Matching Element.
Root Cause​
Access Analyzer maps each scheduled job to a Windows Task Scheduler task using a unique Job ID embedded in the task name (format: SAJOB~<JobGroupName>~<GUID>). When two physical job folders on disk share the same Job ID, Access Analyzer finds more than one match for a single task, which produces the Sequence contains more than one matching element error.
This duplication happens in one of two ways:
Cause 1 — Upgrade Backup ZIP Extracted into the Jobs Folder​
During an upgrade, the Upgrade Wizard automatically backs up the existing Jobs directory by creating a timestamped ZIP archive directly inside the Jobs folder:
...\STEALTHbits\StealthAUDIT\Jobs\<YYYYMMDDHHMMSS>.zip
If an administrator later extracts the contents of that ZIP back into the Jobs folder (e.g., to recover a job), the original job folders and their IDs are restored alongside the already-upgraded copies, which creates duplicates.
Cause 2 — Job or Job Group Folder Manually Copy-Pasted inside the Jobs Folder​
An administrator backed up a job group by copying its folder and pasting the copy somewhere inside ...\STEALTHbits\StealthAUDIT\Jobs instead of moving it to an external location or archiving it. Copying a job within the Jobs directory is not supported (see Instantiating Jobs into the Jobs Tree). The copied folder retains the same job definition file with the same Job ID, producing a duplicate.
Resolution​
Step 1 — Identify the Duplicated Job​
Find the task name in the error message on the Schedules tab. The second segment is the job group folder name and is located between the ~~ characters. For example, in SAJOB~SG_LocalAdmins~<GUID>, the job group folder is SG_LocalAdmins.
Step 2 — Locate the Duplicate in the Jobs Folder​
Navigate to the Jobs directory on the Access Analyzer server:
%SAInstallDir%\Jobs\
The default path (unless customized during install) is:
C:\Program Files (x86)\STEALTHbits\StealthAUDIT\Jobs\
Look inside the job group folder identified in Step 1 (e.g., SG_LocalAdmins). You should see either:
  • A second subfolder or a copy of the job group folder (e.g., SG_LocalAdmins - Copy, SG_LocalAdmins_backup)
  • An extracted ZIP from the upgrade backup — recognizable by the timestamp folder name (e.g., 20230604180542) sitting inside Jobs\ and containing duplicate job group subfolders
Step 3 — Remove the Duplicate​
  1. Close the Access Analyzer console.
  2. Move the duplicate folder (the backup copy) out of the Jobs directory by doing one of the following:
    • Compress it to a ZIP and store it outside %SAInstallDir%\Jobs\.
    • Delete it if the backup is no longer needed.
    If the duplicate came from an extracted upgrade ZIP, move the entire extracted timestamp folder (e.g., 20230604180542\). The upgrade ZIP file itself can remain, because only extracted folder copies cause the conflict. Renaming the GROUP_ or JOB_ prefix on the duplicate only hides it from the Jobs tree and does not resolve the error.
  3. Do not leave any copy of a job group folder inside Jobs\ unless it is the live, intended version.
IMPORTANT: To prevent the error from recurring, do not extract the upgrade backup ZIP into %SAInstallDir%\Jobs\. To recover a job, extract the ZIP outside the install directory and copy only the job file you need. To back up a job group, store the copy outside the Jobs directory.
Step 4 — Verify​
Open the Access Analyzer console and then the Schedules tab. The error should no longer appear and all scheduled tasks should load correctly.
