Preventing Change Tracker from Recreating Deleted Default Groups
The Netwrix Change Tracker console recreates default groups and their attached configuration templates and compliance reports whenever IIS recycles the application pool, which occurs every 29 hours by default.
Instructions
To prevent default groups from being recreated:
  1. Log in to Change Tracker.
  2. Navigate to Settings > System Settings.
  3. Scroll to the bottom of the page.
  4. Click Show Advanced Options.
  5. Click Add Config Item.
  6. In the Description field, enter CreateDefaultGroups. In the Value field, enter No.
  7. Click Save.
