How to Move Indexed Files
Question
How can you move the indexed files created by Netwrix Data Classification?
Answer
If indexed files need to be moved from one drive to another, refer to the following steps:
Run the Netwrix Data Classification Service Viewer utility:
- if NDC has been upgraded to a newer version, its default location is
%ProgramFiles%\ConceptSearching\ServiceViewer\conceptServiceViewer.exe - if NDC v5.6 has been installed for the first time, its default location is
%Program Files%\Netwrix\Data Classification\ServiceViewer\conceptServiceViewer.exe
Stop the following Netwrix Data Classification services:
- Collector Service
- Indexer Service
- Classifier Service
Copy all CSE files from the original folder (by default, located in either
%ProgramFiles%/ConceptSearching/ConceptDBor%Program Files%/Netwrix/Data Classification/ConceptDB) to a new location. -
Run
conceptConfig.exefrom one of the locations below (default paths), enter the new directory path in the Folder for CSE Files field, and click Save:C:\inetpub\wwwroot\conceptQS\bin
%ProgramFiles%\ConceptSearching\Services\ConceptCollectorService
%ProgramFiles%\ConceptSearching\Services\conceptIndexeror
%Program Files%\Netwrix\Data Classification\Services\ConceptCollectorService
%Program Files%\Netwrix\Data Classification\Services\conceptIndexer -
Start Netwrix Data Classification services using Windows Services Manager.
