How to Partially Rebuild the DQS Index
This article describes how to rebuild corrupted indexes on a single server. This process is designed to avoid the effort-intensive method of rebuilding indexes on multiple servers.
Instructions
- Stop services on the Distributed Query Server (DQS).
- Download a blank copy of the CSE files (
ConceptDB.zip). - Replace the CSE files on the DQS Server with the downloaded blank CSE files.
NOTE:
Text.CSEis not in this download and should be left unchanged.
Delete the following files and folders:
- Lexicon shards folder
Indexer.CSELexiconCache.CSELexiconCacheQS.CSELexiconSizeDistribution.CSEPostingsDistribution.CSEIndexerChecksum.CSE
To reindex the affected content, run the following SQL statement:
UPDATE Pages Set Status = 200 WHERE DQSID = X AND Status > 200
where X is the value of your DQSID.
IMPORTANT: Find the correct DQSID from the NDC configuration.
- Start services on the DQS Server.
Use the following file to replace active NDC files (.CSE):
