Antivirus Exclusions for Netwrix Data Classification
Symptoms
An antivirus suite can slow down or even prevent correct operation of Netwrix Data Classification:
- Reduced speed of processing
- Locked index files or temporary collected files
Cause
Netwrix Data Classification writes information to CSE files in small chunks at short intervals — an antivirus will attempt to read the entire file looking for threats after each writing session.
This considerably slows down processes of the service, as each short writing session is expected to occur frequently, while a full read of a file might take a long time (especially in a larger environment).
Resolution
Add the following exclusions for the antivirus:
NOTE: In Netwrix Data Classification v5.6, the first path to exclude is
C:\Program Files\Conceptseraching\Index
- NDC Index databases: CSE files, located by default
C:\Program Files\Netwrix\Data Classification\Index - Temp files:
C:\Users\SERVICEACCOUNTNAMEHERE\AppData\Local\Temp\Netwrix\Data Classification\Collector
During data collection, a collector uses a specific to store copies of the files it is currently collecting and then places them in the temp location until they have been processed and moved on to the Indexer and Classifier services.
