How to Change the Default IIS Port for Netwrix Data Classification Web Console?
Question
How to change the port 80 that comes with a default Netwrix Data Classification installation?
Answer
The default IIS configuration of the Netwrix Data Classification is typically performed on the Administration Web Application step of the installation procedure. Learn more in Deployment — Install Netwrix Data Classification — v5.7
Follow the steps below to change the default IIS port for the web console:
  1. Start the IIS Manager: navigate to Control Panel Administrative Tools > Internet Information Services (IIS) Manager.
  2. In the Connections menu on the left, expand Sites > Default Website.
  3. Click the Bindings link under Actions.
  4. In the Site Binding window, click Edit.
  5. Modify the binding port, for example, 403.
The new port is now set.
