Keyset does not exist ( exception from HRESULT : 0x80090016)
Scenario
Netwrix Data Classification displays the following error:
Error: There was an error while performing this operation.
Details:
Solution
You can regenerate these machine keys without reinstalling IIS completely. To do that follow the steps below:
  1. Rename the files listed below or move them to a different location from C:\ProgramData\Microsoft\Crypto\RSA\MachineKeys\
    • iisConfigurationKey 6de9cb26d2b98c01ec4e9e8b34824aa2_GUID
    • NetFrameworkConfigurationKey d6d986f09a1ee04e24c949879fdb506c_GUID
    • iisWasKey 76944fb33636aeddb9590521c2e8815a_GUID
  2. Backup applicationhost.config, then delete everything inside the tags below in applicationhost.config. Delete the contents within the configProtectedData or providers sections:
<configProtectedData>
<providers>
</providers>
</configProtectedData>
  1. Open a command prompt in admin mode and run the command below:
"%windir%\system32\inetsrv\iissetup.exe /install SharedLibraries"
  1. Keys should be recreated in the C:\ProgramData\Microsoft\Crypto\RSA\MachineKeys\ folder. Now the IIS App pool user can be changed.
These steps, along with more information, can be found here as well: https://techcommunity.microsoft.com/t5/iis-support-blog/keyset-does-not-exist-exception-from-hresult-0x8009000d-or-or/ba-p/342955
