Rolling Log Fix: "ERROR NNT.Hub.ServiceClient.HubAdapter - HubAdapter.Authenticate() Error Authenticating to Hub"
Symptoms
# Example Message: #
2018-07-31 13:03:22,240 [HubClient-PollHubThreadProcessing] ERROR NNT.Hub.ServiceClient.HubAdapter -
HubAdapter.Authenticate() Error authenticating to hub at https://example.ip/api/ - Error writing headers (Error
while sending TLS Alert (Fatal:InternalError): System.IO.IOException: The authentication or decryption has failed. --->
System.IO.IOException: EndRead failure ---> System.Net.Sockets.SocketException: Connection reset by peer
Cause
If you have recently disabled TLS 1.0/1.1 on your Windows Hub, it is likely that a few of your Linux devices are offline and cannot connect to your Hub (mostly disabled for audit/compliance standards).
If the Linux device is currently at Mono 4.5, you will receive this error if you disable TLS 1.0/1.1 on your Windows Hub.
Since Mono 4.5 has compatibility issues with TLS 1.2, you will need to upgrade Mono to a later version (Mono 5.0.1.1). Instructions below on how to install/remedy this issue.
Resolution
If you are receiving this error, the Netwrix Agent is NOT reporting to your hub. This is a critical error, and for monitoring to continue, it must be resolved. To resolve this error:
  1. Stop the Netwrix Agent Service:
    # service nntgen7agent stop
  2. Download the nnt-mono-5.0.1.1-5.x86_64.rpm package.
  3. Copy the download over to a directory on the Linux device (e.g., /tmp directory).
  4. Change directory to that folder:
    # cd /tmp
  5. Next, upgrade to the downloaded mono package:
    # rpm -Uvh nnt-mono-5.0.1.1-5.x86_64.rpm
  6. Start the Netwrix Agent Service:
    # service nntgen7agent start
This will need to be done to all Linux devices that have been disconnected and show this error.
