Creating and Managing Dynasties
Applies To
Netwrix Directory Manager 11
A Dynasty is a set of groups automatically created and managed in Netwrix Directory Manager based on unique values of a selected Active Directory attribute (the Group By attribute). For example, if you group by Department, Netwrix Directory Manager creates a group for each department and adds users to the appropriate group according to their department value.
You can also create nested Dynasties by grouping on multiple attributes, such as Country and City. In this case, city groups are nested within their respective country groups.
Child groups are standard security groups or distribution lists. Netwrix Directory Manager Automate keeps group membership up to date: when a user’s attribute changes (for example, their department), they are automatically moved to the correct group. New groups are created as needed, and groups with no members can be deleted automatically (if configured).
Child groups inherit properties from their parent Dynasty, including group type, security settings, expiry policy, owner, delivery restrictions, and message size limits. This automation saves significant time compared to manually creating and managing groups and their settings.
Dynasty Templates
Netwrix Directory Manager offers three types of Dynasty templates to help you get started:
  • Organizational Dynasty: Creates a child group for each Company, Department, and Title.
  • Geographical Dynasty: Creates a child group for each Country, State, and City.
  • Managerial Dynasty: Creates a child group for the direct reports of each manager, including subordinates of the manager's direct reports.
  • Custom: Creates a Dynasty by AD attributes of your choice.
The three templates are configurable, whereas the custom Dynasty can fulfill numerous other requirements.
Instructions
Creating an Organizational Dynasty
  1. In Netwrix Directory Manager Portal, select Create New > Organizational Dynasty template and click Next.
    Selecting Organizational Dynasty template
  2. On the Group Options page, enter the group name, select the container where the group will be created, and specify the group type, scope, and security settings.
    Group Options page
  3. On the Dynasty Options page, review and modify the attributes that will be used to create child groups. For example, you can remove Title and add Office as needed.
  4. On the Query Options page, review the current configuration of your Dynasty. You can click Query Designer to launch the Query Designer, where you can modify the query to filter the objects for group membership. For example, you may filter out disabled users or get a specific employee type.
    Query Options page
  5. Once your query is complete, proceed to the Update Options page. The Dynasty can be updated manually or via an automated schedule.
    Update Options page
  6. On the Owners page, you can specify additional owners for the group. By default, Netwrix Directory Manager sets the logged-in user as the primary owner. The primary owner will be inherited by all child groups. You can add additional owners by clicking the Add button. Users, contacts, and even security groups can be set as additional owners.
    Owners page
  7. The Completion page gives a summary of the selected settings. Click Finish.
  8. If you selected Now for your update options, a parent Dynasty will be created with the name provided on the Group Options page, and child groups will be created according to the configured template.
NOTE: The Dynasty created in this article is just an example; you can customize the naming template, separator, inheritance, and much more.
