Enforce Group Naming Convention and Input Validation with Regular Expressions
Overview​
This article explains how to enforce group naming conventions and input validation in Netwrix Directory Manager (formerly GroupID) by using regular expressions. Administrators can define naming policies for groups created through the User portal by configuring regular expressions for input fields.
Enforcing naming standards is especially important when users have access to Active Directory via the User portal. The process involves two main steps:
  • Create a display type
  • Associate the display type with the desired field
Instructions​
Create a Display Type​
  1. In the Directory Manager Admin Panel, select Applications. Click the three-dot icon on the desired portal/application and select Settings.
    Accessing application settings in GroupID Admin Panel
  2. Under Design Settings, select your identity store’s name to expand it.
    Expanding identity store under Design Settings
  3. Select Custom Display Types and click Add.
    Adding a custom display type
  4. On the New Display Type page, enter a name for the display type in the Name box (for example, Regular Expression Policy 1). From the Type list, select Textbox and click OK. Complete the other options as described below:
    FieldDescription
    Default ValueSpecify a default value to display in the textbox.
    Regular ExpressionEnter a regular expression to validate the data entered in the textbox.
    Error MessageEnter the error message to display when the input does not match the regular expression.
    Configuring regular expression and error message for display type
  5. Click OK and then Save to save your changes. The new display type appears under Custom Display Types.
Associate the Display Type with a Field​
  3. Scroll down and click Create Object. Under Select Directory Object, select Group from the drop-down list.
  4. In the Name list, select General and click Edit.
    Editing general settings for group object
  5. On the Edit Design Category page, select Group name in the Fields area and click Edit.
    Editing group name field
  6. On the Edit Field page, select the display type you created (for example, Regular Expression Policy 1) from the Display Type drop-down list.
    Selecting display type for group name field
  7. Click OK twice to close the dialog boxes, then scroll down and click Save to apply the changes. The display type is now linked to the Group name field in the Create Group wizard.
Result​
The naming convention defined by the regular expression ensures that group names meet your requirements. For example, if the policy allows only alphabetic characters, the portal will reject names with spaces or special characters and display the specified error message.
Error message for invalid group name input
Regular Expression Examples​
  • Example 1: Allow only alphabetic characters (A–Z, a–z) and digits (0–9), with a length of 1 to 25 characters.
    ^[A-Za-z0-9-]{1,25}$
  • Example 2: Allow alphabetic characters, digits, underscores (_), hyphens (-), asterisks (*), commas (,), and spaces, with a length of 1 to 30 characters.
    ^[A-Za-z0-9-,_*\s]{1,30}$
  • Example 3: Enforce North American phone number format: (555) 123-4567.
    ^\ (\d\d\d\) \d\d\d-\d\d\d\d$
  • Example 4: Accept telephone numbers in the format: 1 555 555 5555.
    ^[01]?[- .]?(\([2-9]\d{2}\)|[2-9]\d{2})[- .]?\d{3}[- .]?\d{4}$
