How to Customize Notifications
This article explains how to customize notification templates in Netwrix Directory Manager (formerly GroupID). Directory Manager generates notifications for events such as group management, workflows, and profile validation. These notifications are sent to administrators, object owners, and other specified recipients.
Email notification templates are predefined and can be customized for the following elements:
  • Logo
  • Subject line
  • Message content and formatting
Instructions
  1. Log in to the Directory Manager Admin portal and click Notification Editor. The editor displays a list of all notifications generated by Directory Manager.
    Notification Editor in Directory Manager Admin portal
  2. Select an event from the Category list to view related notifications. You can also enter a search string and click Search to filter notification names.
  3. Double-click a notification template to open it for editing.
  4. Click the HTML or Source tiles in the ribbon to edit the template in the WYSIWYG or HTML editor.
  5. Customize the template as needed:
    • Change the logo: Remove the current logo and insert a new one.
    • Change the subject line: Click the Title tile. In the Edit Title dialog box, update the subject line and click OK.
    • Format the notification content: Use formatting options to apply heading styles, change font and size, adjust alignment, and more.
    • Modify the notification content: Edit the message as needed. You can replace tags with other relevant tags. Tags display attribute values in the notification and are formatted as %ATTRIBUTE_NAME%. For example, %TARGETOBJECT_DisplayName% displays the display name of the target object, and %REQUESTOR_mail% shows the requestor's email address. Click the Dictionary tile to view available tags.
  6. Click Save to apply your changes.
    Editing and saving a notification template in Directory Manager
