How to Collect and Compress Logs in V11
Overview​
To help troubleshoot issues, follow this procedure to collect all relevant Netwrix Directory Manager (formerly GroupID) logs from your machine, including:
  • Non-portal service logs (AdminCenter, EmailService, DataService, Scheduler, Security, Replication).
  • All Directory Manager Portal logs (auto-discovered).
  • Complete Elasticsearch logs folders under ...\elasticsearch\* (version-agnostic; copies all file types: .log, .json, .zip, .gz, .tar, etc.).
  • Additional ProgramData folders you specify.
NOTE: Netwrix Directory Manager is used as the product name in this article. The product is historically known as GroupID; the folder and log names in the script retain the original "GroupID" names to preserve accuracy for file paths and registry keys."
The script preserves the folder structure and compresses all files into a single, timestamped ZIP file named with the machine’s hostname to streamline handoff in support cases.
Instructions​
Variables to Prepare​
  • $extraDataFolders — Additional ProgramData folders to include, should be left to default unless changed manually:
"C:\ProgramData\Imanami\GroupID 11.0\Configuration Tool",
"C:\ProgramData\Imanami\GroupID 11.0\Upgrade Tool"
  • $tempLogDir — Staging directory for collected logs (e.g., C:\Temp\GroupID_Collected_Logs).
The script automatically discovers any logs directory under ...\elasticsearch\* beneath $rootPath, e.g. C:\Program Files\Imanami\GroupID 11.0\elasticsearch\elasticsearch-8.0.0\logs.
PowerShell Script​
# --- Discover GroupID install path from Registry (Version 11.0) ---
function Get-GroupIDRootPath {
$subkey = "SOFTWARE\Imanami\GroupID\Version 11.0"
$views = @(
[Microsoft.Win32.RegistryView]::Registry64,
[Microsoft.Win32.RegistryView]::Registry32
foreach ($view in $views) {
try {
$base = [Microsoft.Win32.RegistryKey]::OpenBaseKey([Microsoft.Win32.RegistryHive]::LocalMachine, $view)
$key = $base.OpenSubKey($subkey)
if ($key) {
$val = $key.GetValue("Path", $null)
if ($val) {
# Normalize: remove trailing backslash
return ($val.TrimEnd('\'))
} catch { }
return $null
$rootPath = Get-GroupIDRootPath
if (-not $rootPath) {
Write-Warning "GroupID install path not found in registry. Falling back to default."
$rootPath = "C:\Program Files\Imanami\GroupID 11.0"
# --- Settings you may customize ---
$extraDataFolders = @(
$tempLogDir = "C:\Temp\GroupID_Collected_Logs"
# Fresh staging directory
if (Test-Path $tempLogDir) { Remove-Item -Path $tempLogDir -Recurse -Force }
New-Item -Path $tempLogDir -ItemType Directory | Out-Null
# Non-Portal log subdirectories (relative to $rootPath)
$nonPortalLogFolders = @(
"AdminCenter\Inetpub\AdminCenter\Web\Logs",
"EmailService\Inetpub\GroupIDEmailService\Web\Logs",
"GroupIDDataService\Inetpub\GroupIDDataService\Web\Logs",
"GroupIDSchedulerService\Inetpub\GroupIDSchedulerService\Web\Logs",
"GroupIDSecurityService\Inetpub\GroupIDSecurityService\Web\Logs",
"ReplicationService\Inetpub\GroupIDReplicationService\Web\Logs"
# Copy *.log from non-portal folders
foreach ($subfolder in $nonPortalLogFolders) {
$sourceFolder = Join-Path $rootPath $subfolder
if (Test-Path $sourceFolder) {
$folderName = Split-Path $subfolder -Leaf
$destFolder = Join-Path $tempLogDir $folderName
New-Item -Path $destFolder -ItemType Directory -Force | Out-Null
Get-ChildItem -Path $sourceFolder -Filter *.log -File -ErrorAction SilentlyContinue | ForEach-Object {
Copy-Item -Path $_.FullName -Destination $destFolder -Force -ErrorAction SilentlyContinue
# Portal logs: auto-discover portals under GroupIDPortal\Inetpub
$portalRoot = Join-Path $rootPath "GroupIDPortal\Inetpub"
if (Test-Path $portalRoot) {
Get-ChildItem -Path $portalRoot -Directory -ErrorAction SilentlyContinue | ForEach-Object {
$portalName = $_.Name
$logsFolder = Join-Path $_.FullName "Web\Logs"
if (Test-Path $logsFolder) {
$destFolder = Join-Path $tempLogDir ("Portal_" + $portalName)
Get-ChildItem -Path $logsFolder -Filter *.log -File -ErrorAction SilentlyContinue | ForEach-Object {
# Copy Additional ProgramData Folders (all contents)
foreach ($extraFolder in $extraDataFolders) {
if (Test-Path $extraFolder) {
$folderName = Split-Path $extraFolder -Leaf
Copy-Item -Path $extraFolder -Destination $destFolder -Recurse -Force -ErrorAction SilentlyContinue
# Collect Elasticsearch logs (entire folders; any file type)
$esDumpRoot = Join-Path $tempLogDir "ElasticsearchLogs"
New-Item -Path $esDumpRoot -ItemType Directory -Force | Out-Null
try {
if (Test-Path $rootPath) {
$esRoots = Get-ChildItem -Path $rootPath -Directory -Recurse -ErrorAction SilentlyContinue |
Where-Object { $_.Name -like 'elasticsearch*' }
foreach ($esRoot in $esRoots) {
$logsDirs = Get-ChildItem -Path $esRoot.FullName -Directory -Recurse -ErrorAction SilentlyContinue |
Where-Object { $_.Name -eq 'logs' }
foreach ($ld in $logsDirs) {
$instanceName = Split-Path $ld.Parent.FullName -Leaf
if ([string]::IsNullOrWhiteSpace($instanceName)) { $instanceName = "elasticsearch_logs" }
$destInstanceRoot = Join-Path $esDumpRoot $instanceName
New-Item -Path $destInstanceRoot -ItemType Directory -Force | Out-Null
# Preserve entire logs directory (includes .log, .json, .zip, .gz, .tar, etc.)
Copy-Item -Path $ld.FullName -Destination $destInstanceRoot -Recurse -Force -ErrorAction SilentlyContinue
catch {
Write-Warning "Failed to collect Elasticsearch logs: $($_.Exception.Message)"
# Create timestamped ZIP with hostname
$timestamp = Get-Date -Format "yyyyMMdd_HHmmss"
$hostname = $env:COMPUTERNAME
$zipPath = "C:\Temp\GroupID_Logs_${hostname}_$timestamp.zip"
Compress-Archive -Path "$tempLogDir\*" -DestinationPath $zipPath -Force
Write-Output "Logs compressed to $zipPath"
Result​
  • Non-portal logs: All *.log files under standard GroupID service log paths are copied into corresponding subfolders in $tempLogDir (e.g., AdminCenter, GroupIDDataService, etc.).
  • Portal logs: Each portal instance under GroupIDPortal\Inetpub becomes a folder like Portal_<PortalName> containing its *.log files.
  • Elasticsearch logs: A top-level folder ElasticsearchLogs\<instance>\logs\... is created under $tempLogDir for each discovered instance. The entire logs directory is copied, preserving structure and including all file types (.log, .json, .zip, .gz, .tar, etc.).
  • Extra data folders: Every path in $extraDataFolders is copied recursively with structure preserved.
  • ZIP output: A single archive is created at C:\Temp\GroupID_Logs_<hostname>_<timestamp>.zip and the script prints the full path.
Additional Information​
  • Uses -Force to overwrite existing files when staging and compressing.
  • Preserves structure for Elasticsearch and extra data folders to retain context for troubleshooting.
  • Hostname and timestamp in the ZIP name prevent collisions and identify the source system.
  • -ErrorAction SilentlyContinue avoids noisy output in restricted environments while still completing the collection.
Uploading Logs​
  1. Log in to Netwrix Support Portal.
  2. Navigate to My Tickets and locate your ticket number.
  3. Click Add Attachments and upload the ZIP file that was created at C:\Temp\GroupID_Logs_<hostname>_<timestamp>.zip.
For additional resources or information, visit the Technical Support Resource Hub.
Troubleshooting Tips​
  • Access denied: Run PowerShell as Administrator to ensure access to Program Files and ProgramData paths.
  • Long paths / locked files: If compression fails, re-run after services are stopped or consider excluding very large archives temporarily.
  • Different install root: If GroupID is installed elsewhere, update $rootPath accordingly—the Elasticsearch discovery remains version-agnostic.
Security & Privacy of Customer Data​
Customer data provided to Netwrix through the customer support portal is encrypted in transit and at rest.
Netwrix follows a security framework such as NIST-800-53 and requires all devices that handle confidential information be encrypted and maintain up-to-date security solutions per the Information Security policies.
Customer-provided data is retained no longer than 30 days post ticket closure.
