Invoke Management Shell from PowerShell 7 in v11
Applies To
Netwrix Directory Manager 11
This article explains how to remotely invoke the Management Shell from PowerShell 7 in Netwrix Directory Manager version 11. It covers the process of establishing a remote session, importing the necessary modules, and connecting to an Identity Store using credentials. This method allows you to run Netwrix Directory Manager cmdlets in PowerShell 7 without directly signing into the Netwrix Directory Manager server.
Instructions
Follow the steps below to remotely connect to the Management Shell:
  1. Open PowerShell 7 as an Administrator.
  2. Enter the following cmdlet and update the placeholders with the correct values:
  • DOMAIN\USERNAME – Replace with the domain and username of your account.
  • USER-PASSWORD – Replace with your actual password (in plain text).
  • YOUR MACHINE NAME HERE – Replace with the name of the Directory Manager server.
  • IDENTITYSTOREID HERE – Replace with the appropriate Identity Store ID.
$username = "DOMAIN\USERNAME"
$pass = ConvertTo-SecureString "USER-PASSWORD" -AsPlainText -Force
$Cred = New-Object System.Management.Automation.PSCredential ($username, $pass)
$s = New-PSSession -ComputerName "YOUR MACHINE NAME HERE" -Credential $Cred -ConfigurationName PowerShell.7
Invoke-Command -Session $s -ScriptBlock {
$srcu = [reflection.assembly]::LoadFrom('C:\Program Files\PowerShell\7\System.Windows.Forms.dll')
$OnAssemblyResolve = [System.ResolveEventHandler] {
param($sender, $e)
if ($e.Name -like "System.Windows.Forms, Version=*") {
return $srcu
return $null
[System.AppDomain]::CurrentDomain.add_AssemblyResolve($OnAssemblyResolve)
$reg = Get-ItemProperty -Path HKLM:SOFTWARE\Microsoft\PowerShell\1\PowerShellSnapIns\Imanami.Groups.Management.PowerShell.Admin11
$appbase = $reg.ApplicationBase
Import-Module -Name "$appbase\GroupIDManagementShell\bin\Imanami.GroupID.Management.dll"
Set-ModulePath -ModulePath "$appbase\GroupIDManagementShell\bin"
Import-PSSession -Session $s -Type cmdlet -AllowClobber
Connect-IdentityStore -mode "2" -IdentityStoreID "IDENTITYSTOREID HERE" -Credential $Cred
  1. Once the script completes, a remote session will be established. This allows you to run Netwrix Directory Manager cmdlets in PowerShell 7 without logging directly into the Netwrix Directory Manager server.
