Replicating Custom AD Attributes to Elasticsearch
Applies To
Netwrix Directory Manager 10
Netwrix Directory Manager 10 allows you to replicate custom Active Directory (AD) attributes to the Elasticsearch repository. This article provides instructions for adding a custom attribute to the AD schema and configuring Netwrix Directory Manager to include it in replication.
Instructions
  1. Create the custom attribute in the Active Directory schema. For example, to add campusName for users, define the attribute in the AD schema and assign it to user objects. Once completed, the attribute will appear in the attribute list for users in AD.
  2. On the Netwrix Directory Manager machine, open Task Scheduler and run the task named Schema Replication.
    Task Scheduler with Schema Replication task highlighted
  3. After the Schema Replication task completes, open the Netwrix Directory Manager Management Console and click the Identity Stores node.
  4. On the Identity Stores tab, double-click the required identity store to open its properties.
  5. On the Replication tab, add the custom attribute you created.
    Replication tab in Identity Store properties with custom attribute added
  6. Once complete, open Services and restart the Elasticsearch service and the Netwrix Replication service.
  7. Open regedit.msc and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Imanami\GroupID\Version 10.0\Replication.
  8. Expand the Replication registry key to view your identity stores. Select your domain’s identity store, and in the users value, delete the existing value data. Click OK to save your changes. This action forces a full replication of user objects, ensuring the new attribute is included in Elasticsearch.
    Registry editor showing Replication key and users value
  9. In the Netwrix Directory Manager Management Console, go to the Replication tab for the identity store and click Replicate Now in the Replication Service area. This starts users-only replication for your domain. Once complete, your custom attribute will be included in Elasticsearch.
