Configure Session Timeout Settings for the Administration Interface
Netwrix Endpoint Protector Server includes a session timeout feature for the Administration Interface to enhance security. You can configure session timeout settings to control how long a user session remains active during periods of inactivity. These settings help protect the management console from unauthorized access due to unattended sessions and complement other system security features, such as role-based access controls.
Instructions
Go to System Configuration > System Settings > Session Settings in the Netwrix Endpoint Protector Management Console.
Modify the session timeout settings as needed:
- Session Timeout: Set the amount of time (between
5and60minutes) a user can be inactive before the session expires. - Timeout Counter: Set the countdown duration (between
5seconds and one minute less than the Session Timeout) for the session timeout warning.
NOTE: If Session Timeout is set to
5minutes and Timeout Counter is set to60seconds, after4minutes of inactivity a pop-up window will notify you that you will be logged out in60seconds.
- If no activity occurs during the countdown, Netwrix Endpoint Protector displays a message indicating the session will expire. You can choose to log out or continue your session, which resets the session timeout interval.
