Setting Up External Storage
This article outlines how to configure external storage to conserve hard drive space on the server. External storage in Endpoint Protector is the File Shadow Repository. It directs File Shadows (copies of files transferred by monitored endpoints) to a remote location instead of storing them on the appliance's local disk, which helps conserve server disk space and centralizes shadow storage.
NOTE: System Backups are not affected by this setting. They are stored on and downloaded from the appliance itself; Endpoint Protector has no external storage destination for backups.
Endpoint Protector supports the following repository types: File Transfer Protocol (FTP), Samba (smbv1), Samba v2 (sambav2), S3 Bucket, and Azure Blob. Azure Blob repositories require Endpoint Protector Client 2611 or later. For the full configuration reference, including field requirements for each repository type and S3 Bucket-specific setup (regions, artifact retrieval methods, and domain whitelisting), see File Shadow Repository.
Instructions
In the Endpoint Protector Console, navigate to System Maintenance > File Shadow Repository.
Click Add, then assign one or more Departments to the repository.
NOTE: In Endpoint Protector, a Department defines a collection of entities that share the same attributes. Do not confuse it with a department from an organizational chart.
Select the Repository Type: FTP, Samba (smbv1), Samba v2 (sambav2), S3 Bucket, or Azure Blob.
Complete the fields required for the selected repository type — Repository IP Address, Port, Folder Path, Username, and Password for FTP and Samba types, or the type-specific fields for S3 Bucket and Azure Blob. See File Shadow Repository for the full field list per type.
Save your settings.
Wait a few minutes, then click Test to verify that the server can connect to the external storage and copy or create files.
NOTE: The Test button supports FTP, S3 Bucket, and Azure Blob repositories. It is not supported for Samba (smbv1) or Samba v2 (sambav2), due to additional third-party requirements such as IP whitelisting.
When access succeeds, the server creates three folders and a .txt file in the external storage location.
