Upgrade Linux Clients Without Uninstalling and Reinstalling
This article explains how to upgrade the Endpoint Protector client on Linux without performing a full uninstall and reinstall. The steps below allow you to upgrade the client while preserving configuration variables from the previous build.
Instructions
  1. Copy the new Endpoint Protector client installer to the Linux machine.
  2. Open a Terminal window.
  3. Export the variables from the options.ini file from the older build:
    export EPPCLIENT_WS_SERVER=ip.of.the.server
    export EPPCLIENT_WS_PORT=443
    export EPPCLIENT_DEPARTMENT_CODE=defdep
  4. Unpack the archive:
    tar xvf [Filename.tar.xz]
  5. From the unpacked directory of the newer build, run:
    sudo -E apt install ./pkgs/*.deb
  6. Open Endpoint Protector Notifier and confirm that the Endpoint Protector client was upgraded.
