Block File Transfers to or from Network Shares
This article explains how to block file transfers to or from network shares using the Content Aware Protection policy.
Instructions
- Ensure that Network Share is selected in the Content Aware Protection policy.
- Navigate to Denylists and Allowlists > Denylists.
- Select the File Location tab.
- Click the Add button.
- In the Content text box, add the network share path without the two leading backslashes (
\):- This is correct and will block file transfers:
192.168.10.10\test - This is incorrect and will not block file transfers:
\192.168.10.10\test
- In the Groups or Computers section, select the computers or groups that the denylist should be applied to.
- Save the changes.
