Configuring Rights for Outside Hours and Outside Network
This article explains how you configure rights for Outside Hours and Outside Network in Netwrix Endpoint Protector. These settings allow you to define different device and content access rights based on time and network conditions.
Instructions
  1. In the Netwrix Endpoint Protector Console, navigate to Device Control and select your configuration level:
    • Global: Global Settings > Outside Hours and Outside Network.
    • Computer, User, or Group: Computer/User/Group Settings > Manage Settings.
  2. To configure the Outside Hours policies, enable the Outside Hours setting, then set the Working Days, Business Hours Start Time, and End Time.
  3. To configure Outside Network policies, enable the Outside Network setting, then add the DNS Fully Qualified Domain Name and DNS IP Addresses.
  4. Set fallback device type rights as needed by configuring fallback rights globally, or per group, user, or computer.
  5. For Content Aware Policies, select the Outside Network and Outside Hours policy types as required.
IMPORTANT: When triggered, fallback policies supersede the standard device rights. For fallback policies, Outside Network Policies take precedence over Outside Hours Policies.
