Error: Devices Not Visible in List of Devices
Symptom​
New devices connected to a protected computer are not visible in the system's List of Devices.
Cause​
This issue may occur if the Endpoint Protector (EPP) Client is not communicating with the EPP Server, or if the device has not been properly recognized or registered by the system.
Resolutions​
  1. Verify the device status:
    1. Open the EPP Client notifier by double-clicking the EPP Client icon in the task bar.
    2. Check if the EPP Client is communicating with the EPP Server by reviewing the Last Server Connection status.
    3. On the Settings tab, press Ctrl + Alt + I (Windows) or Command + Option + I (macOS). Confirm that YES appears next to Connected.
    4. Check if the device is visible under the Device Control tab in the EPP Client.
  2. Unplug the device and restart the computer. After the restart, reconnect the device to the computer and update EPP Client policies.
  3. Manually create a new device by providing the device parameters and information under List of Devices:
    1. Navigate to Device Control > Devices > Create.
    2. Save the newly added device and retest.
