How to Back Up Data from a USB Drive When Experiencing Easylock Issues
If you are experiencing problems with Easylock, you can attempt to back up your data by following the step-by-step instructions below. These procedures are designed to help you secure your data and maintain access should issues arise.
Instructions
  1. Enable write access on the USB drive.
  2. Copy all files from the root directory of the USB drive to a local folder as a backup.
  3. Open the Enforce Encryption section, select Manual Deployment, and choose your USB device.
  4. Download the Easylock software package.
  5. Extract the Easylock client files to your local computer.
  6. Replace the Easylock.exe file on the USB drive with the extracted version.
After completing these steps, you may be able to restore access to Easylock and secure your data.
